hey guys
just bought a apexi AFC Neo. Im not sure about the wiring though
would anyone be able to point me in the right direction? iv looked on the tech section on the forum but its only got the installation of the SAFC II.
Would the neo use the same wiring diagram as the SAFC II?
I would like to install in myself because then thats an extra $300 or so i can use on tuning or something else :laugh:
https://www.sau.com.au/forums/topic/249621-apexi-neo-wiring/
hey guys
hyperdrive can install that for 150. :D not sure how to install it myself too...
hey guys
hey mani have the wiring diagram,,, took me 30 minstoo install mine :rofl:
This should help. These two diagrams apply for the R33 GTSt.
If you need any more help, drop me a PM, installing mine last year was pretty easy.
Alternate URL: http://skylineswiki.com/Image:Apexineo-r33-01.jpg
Alternate URL: http://skylineswiki.com/Image:Apexineo-r33-02.jpg
ah brilliant cheers bud :banana:
should help
now its just a matter of connecting all nececary wires hey
o yea one more thing lol
is the settings for the basic tune the same as the SAFC?
Sorry, should clarify incase you're not sure how it works? or for others..
All the settings on the SAFC at 0 = normal ECU tune.
A tuner will adjust these + or - a bit at certain rev ranges to get better air/fuel ratio's at those revs.
The ECU thinks it's sending AFRs to the engine components, but the SAFC intercepts those signals and adjusts them, and then sends them on. What a sneaky little russian eh?
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
