Yokohama rang me last week about tyres for superlap saying that the new AO50 is being used by some front runners at superlap. They were saying that they are a bit quicker and softer. Semi's are gunna be costing drug money soon!
Heya boyz,
Tried every avenue under the sun to get the new RE-11's but simply not available in the Australian market.
With the RE-11 being the replacement for the RE-01R you would assume Bridgestone Oz would need to clear most stock of RE-01R prior, so they dont have conflicting tyres or a plethora of old stock that can't sell. So I suspect there could be 12 months or greater until we see these puppies.
In the end, reverted to current model here RE-01R & looking forward to giving these a good run.
Cheers,
Ben
  • 1 year later...
http://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=118
for a street tyre i dont think u can go past the direzza star specs, plays with the big boys, for not much more $$ than the KU36's.
tirerack can send them from the states for ya.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
    • The pinchweld is fine, even with a trolley jack, so long as you're not actually pushing on the pinchweld itself. More to the point, we shouldn't talk about lifting or supporting on the pinchweld, we should talk about using the sill "jacking points", which just happen to be adjacent to the pinchweld. I just have dense rubber blocks with grooves in them for each of the chassis stands and the trolley jack, that I use at the sill jacking points if/when I have to lift/support there. They put all the load onto the steel pad of the jacking point and not the pinchweld. As intended.
    • Makes sense.  I would do something different if I felt like there was a better option. Generally the only other area I'm happy to jack on is where I want to put the stand. The pinch weld is not an option for me for either the jack or stands, so very limited options overall.  Plus never having had an issue with doing this, has kinda reinforced in my mind that it's fine. I'd do it on any car without a second thought these days lol.
