  • Replies 85
edit---TODAY--i was down at welshpool (getting my licence re-newed, no yellow sticker) there was stuff all cars there, a disgusting red celica with huge chromies, and a pig s13.
THOUGH i went in n came out in 30mins and the line hadnt moved at all. that was around, 2pm
Edited by Char
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4333523
how did you go ricca, no luck for me. got to see if my brides are adr approved, my park light reflector has to be secured, high level stop light, need tyre plark. car re weight. need to have proof that the car doesnt come with a air bag. high beams. (they worked before i left to go) got to fill out this mod form and send it through and prob have to get a engineer to look at it.
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4334598
sorry if i am jacking this thread, but how am i meant to prove that my car doesnt come with air bags
the easiest way to prove you dont have airbags is to look at your dash lights. If you have an airbag, upon igntion of the car, the airbag light will come on for a brief few seconds as a self check. If there is no airbag light at all on the dash...the car never came with it.
Edited by ZXY
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4335789
mmm when i got a yellow and went to the pits i went to the gosnells one *i had a yelloow for a T wing* i got this guy with like skin disorder and he raped me :? saying my suspension is wayyy too hard and couple of other stpuid stuff so i got my mom to take my car over at welshpool and it was done in less then 10 secs :) so yeah if i was to get a yellow again ill get my parents to take car over LOL
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4336067
Well thought i give an update.
I have since my last Check installed a new
Immboiser!!
inner toe arm
fixed the Suspension
and made a bracket for the Zaust
Heading over the pits on Monday not sure where yet i have got a friend which is a Engineer and getting his Cert to Clear his own cars
he would be taking it down so he can talk the talk!!
So hope all goes well!
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4352960
where would the engine number be on the 26, the inspector couldnt find it cause he said the turbos are in the way
Exactly where he's looking. There's a little bit of the block that sticks out, on the passenger side, up against where the gearbox bellhousing bolts onto the block.
He might need to use his little bendy mirror and get at it from the underside..
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4354713
actually found the engine number, i guess on a 26 its different, its directly under the top radiator hose on the block
lol fair enough, they probably moved it after they realised they'd put a bunch of turbos and stuff in the way :)
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4355601
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
