Im looking at putting a auto in my r33 so i will have a manaul conversion ,the box is in perfect working order ,it has round 70 k .ive just had the master cylinder over hauled ,and i have twin plate direct clutch and lighten fly wheel which has round 6 k on it ,the clutch its self is worth round 2k and most of it was just to run in my motor ,it will come with all nuts and bolts ,clutch lines ,slave cylinder ,pedal .tail shaft shifter as well ,if you need it ..everything i pull out you will have .the box is out of a r33 gtst ..
im located in townsville the box is still in the car if you would like some one to test it .or see how it goes into gear ect
i will aslo pack and send it to you for free .australia wide..
im looking round $3500 ono for the whole lot ,and anything eles i pull out and havent mentioned .
if you would like any more info plz pm me
cheers mark .
question is why u having ur skyline on auto? dw mine is auto as well lol...,just wondering thats all
ive been build this car for last 3 years ,and this is the last thing i want to do ..be for i go to the drags ..
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
