hi guys i'm new to this forum name's Nathaniel (nat or nathan for sort) i have a 1996 R33 S2 with 66000 on the clock which i got for $2700 smahed. i got a 4 door S2 nose cut for 500 and have a mate that is a panel beater that is going to pull the front out for $200.
the car come with a brand new X-force turbo manifold, X-force 3" dump pipe into a hi-flow cat into a 3.5" custom exhaust and muffler it also has a HKS EVC 4 Boost Controller
this was the car after 2 days work
some pic's of the stainless steel dran pipe
Any way that all i have for now look like it will be good when it's up and running .
Nat
https://www.sau.com.au/forums/topic/250203-r33-s2/
Happy New Year 09 Nat and welcome to SAU
Project car eh? You've got a daily I presume.
It'll be interesting to see how your rebuild goes. No weakness in the rails?
happy new year to you to. yeah i got the missus a ford as the daily so we can still get the kids around.
i have been up and down the car a s*** loud of times looking for weakness but can't find any. the rails are still good as most of it looks like it went over the top of the rails...so not this weekend but the next it is off to a mates house to go on his puller.(yes there is one in his backyard). can't wait as this is my first turbo car but not the first i have driven. my last Project car was an old 83 HJ60 landcruiser that i turbo.....how i miss the sound of that thing. would come out of a street and ppl would be looking for a mack truck
here a vid of it....and it was stock when i got it.
http://au.youtube.com/watch?v=TjXiSn9STUs&...re=channel_page
https://www.sau.com.au/forums/topic/250203-r33-s2/#findComment-4342545
  • 3 months later...
bar looks schmick man! good job!
hey all got two complete cars non complyable all parts there both under hundy thou on them mint az all parts going cheap az baby on the way and dreams of building track cars all gone will post au wide 0430540512. after market exhausts xforce and jmax. everything make offers and it yours must go cheers
https://www.sau.com.au/forums/topic/250203-r33-s2/#findComment-4599913
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
