Advice Needed On Registering Car Being Bought Over From Nsw
Hello, just wondering if someone can tell me whats involved in getting a car registered in WA that will be bought over from NSW. It's a late model Monaro (about 3-4 yrs old) basically std except for exhaust and lowered. It has also been un-registered over here for the last 5 months - not sure if this will make a difference or not?
Thankyou.
This topic has been covered a bunch of times here already.
But basically; you'll need a temporary moving permit (48hrs) which will allow you to take it to the pits, you'll need to get a inspection done and as long as everything is legal on the car; you should be good to go the same day.
You will need to check that the car has an immobiliser as they're required here but not in the eastern states. If you don't have an immobiliser; you'll need to get one fitted before getting the inspection done.
For the inspection you'll need change of ownership forms and any other related documentation. Also you'll need to make sure all lights/wipers/indicators etc. etc. is in 100% working condition.
dont expect to pass over the first time tho, they will turn you away if you have a slight oil leak. being a comodore it will have plenty :banana: as soon as the car hits WA soil you arnt aloud to drive it so yeh like levinet said.. get a permit, its only about 12 bucks.
prepare to pay about 70 bucks for your first going.. second time will be about 35 from memory.
go first thing in the morning and go to welshpool.
that's what taking it over the pits is for.
Oh and be prepared to pay a fair whack for stamp duty and any sort of contract you had showing purchase price.
My guy let me pass with a minor oil leak which he said to get fixed and I have.
  • 7 months later...
are there any pits here that do inspections by appointments? Last time i went to welshpool the dam line was pass the outside gate. From memory i was there for 3hrs. My car is stock bar cat back so shouldn't have problem passing. More concerned about not waitng to pass. Is midland busy? Also where do i ring for temp moving permit?
Edited by drgnball34
All the centres in Perth are by appointment, I think at Welshpool you can rock up before 8 without an appointment ?? Not to sure about this though. Easier to make an appointment.
Temporary Movement Permits can be purchased over the phone with credit card, or at any licensing centre. $13.85 ?? or something minor, you'll need the VIN/Chassis and Engine number.
Don't forget you will probably have to do an IMS240 test if you have a modified exhaust so budget a couple of grand for that(pits will te3ll you if you need this test)
^^^ its not an import so it'll be fine... LOL.
No really, I bet he'll pass without the IM240 test, its post 89, and naturally aspirated, and its not like the guys at the pits know what theyre looking for either.
any vehicle with an aftermarket exhaust it supposed to have the test :)
Actually, its an R34, not a Monaro, LOL when I read the thread I did notice it was an old one bumped, but for some reason that didnt click when I was replying.
Yeah, R34 Skyline, put another few grand away for emmisions buddy, you'll need it.
picked up my vspec II from nsw last tuesday and took it over the pits on thursday and passed. It has turbo back exhaust, rims and coilovers. Did the inspection at east perth. Really nice guy and was more interested in my car then the inspection lol.
Was the vehicle already registered over East?
if not, no emmisions test?
It was complied march last year and ever since then never been registered and sitting in the yard. But the day before the dealer sent it to the depo he got it registered to nsw. Dont know why thou but it rolled of the train with brand new nsw plates. I didn't need a emmision test.
So you were registering a "vehicle transfer", not registering an unregistered vehicle, that'd be why they didn't ask for an emmisions test.
Although I keep hearing alot of people are passing pits with all stock setups.
so let's say you brought over a car from NSW that had a cat-back...
it is registered but needs WA plates now... if you have a modified exhaust you will need to get the IM240 test?
and on another note: if you go over pits now with a standard exhaust (car already registered here) there will be no IM240 test required correct?
thanks guys
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
