I am thinking of painting my r32 but have no idea what it costs. My main reason for the paint job is because i have a small patch of rust next to the back windscreen and don't know how well the current paint can be colour matched. I know the paint will cost ~$500. What about the labour?? Thanks.
https://www.sau.com.au/forums/topic/25035-how-much-is-a-paint-job-worth/
down to bare metal will end up costing more in product since you will have to prime the whole lot, and if going 2K then it's around $50 a litre for primer, plus $30-$50 for hardener just for that, would need about 3 litres for light coat, or to fix minor imperfections need about 3-5 litres!!! plus rubbing all that back then spray!!!
i did mine recently, did all the work myself then got it sprayed!! cost me about $1800!! took 3 months to prep but!!
details and more info here
Respray Thread
and click link in sig for results!!
could save you about $3K all up!!
Also it depends if you want to repaint it the same colour, or change colour.
For a colour change not to look dodgy, it's an engine out job.
Also, Craved's suggestions sound great - the more prep work you can do yourself, the more cash you will save BUT remember the prep work is the basis for the whole job, if the prep work is poor, the car will look like crap, it's as simple as that.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
