Hello
I am wondering how to hook up an adjustable fuel pressure reg. I know that it goes on the return line just after the std one. But i was wondering do people just pull the vac line off the std one? or do they remove it all together?
It an R33
And there is another thing on the return line too, Is that another reg? or one way valve?
do you have a valid reason as to why you are installing one? If you are just putting one on for the hell of it then don't even worry about it. Put your shiny new one on ebay and sell it.
I'm running 300rwkw+ and still use a factory regulator.
If you put this on, prepare for your car to run like shit or unpredictable.
Edited by The Mafia
dont worry about mafia shotter, he has been spewing his "awesomeness" since 2003.
YES, use the vac source from the stock reg.
however why would u use 2 fpr's?
what type of fpr do u have, ie nismo?
I have a SARD one. And the guy thats going to tune my car said we can put it on there to raise the pressure a bit because i wont be changing the injectors yet. But as far as i know the std one is connected to the fuel rail so i cant really remove it.
Hmm. It took me 6 years to make 2,200 posts.
You, 1.5 years to make 1600 posts.
Lets do some maths:
Me = 1.6 posts per day.
R33Dickhead= 3 post per day.
Plus, you managed to post almost as much as me in just over a year, that it took me 6 years. Oh, and most of your posts are useless horseshit that is not worth reading.
You should go back to installing a Shiny noisy poofter blow off valve to your car, and a big fuel pressure regulator that can support 1000 horsepower. Would go well with that bulk of power you are making.
The points I were getting at is (there is more than one now)
1. If you aren't making more than 200rwkw, you don't need a FPR.
2. R33cruiser talks shit and should be banned from the forced induction section, and joined to the ricer bolt shiny thing on dickhead forum called www.nissansilva.com
Anyway, if you would like some further insight, just let me know. THe only insight you'll get from R33cruiser is the insight from the inside of his ass, as thats where his head is.
Edited by The Mafia
Careful with the sard one, most cars i Have tuned with sard ones I have had to pull them off due to regulation problems. They were all over tne shop with AFRs and proved useless to tune. Same deal with Malpassi.
Just curious, what are you mods?
If you are still running the standard turbo, then that will max out before the Injectors will, they usually hit 95% duty cycle at about 230rwkw - 240rwkw.
But anyway, a mod listing will be good.
Also, your original question - yes, you need a vac line on the FPR, as it also supplies boost to it, and will raise the pressure for every psi of boost it sees. The Factory FPR gives one extra PSI of fuel for every extra PSI of boost is sees. THe base pressure for a R33 is 43psi.
Edited by The Mafia
The last dyno run i had done was 210rwkw at 10psi. The car has a front mount intercooler, the turbo has been rebuilt, made bigger and the ceramic wheel replace with a steel one. fuel pump replace with a 023, 2 stage electronic boost controller. basically my tuner said it is possable to push more power out of the std injectors by raising the fuel pressure. and i thought i could hook it up before i get there so i dont have to waste money on him doing it. Can someone tell me what else is on the return line. There is a right angle fitting about a foot down from the std fuel reg. What does this do? it kinda looks like another fuel reg just without the vac line fitting.
Lets do some maths:
F***ing SNAP!!!!
Lol. But Mafia is right, FPR's on basically stock cars trying to "squeeze" extra power out of the stock injectors by bumping up the fuel pressure isn't the best idea and isn't highly recommended. Get yourself some cheap second hand S15 injectors if you only want a little bit more headroom from your injectors.
I plan to get bigger injectors in the future but for the moment im thinking about just putting in the adj fuel reg and seeing what it can do. Can anyone tell me what the right angle fitting thing is thats on the return line?
sorry mate, I haven't changed one before so I have told you all that I can tell you.
I'm sure there is someone that has done it before.
Just remember you can push the stock injectors to almost 240rwkw. Won't that be enough? I don't recommend pushing too muc more out of them, one might beak and cause a catastropic failure.
It is the std one but it has been rebuilt, borred out and the ceramic wheel has been replaced with a steel one. Some company rebuilds them and does all of this. I think it is now rated at 450hp but im not sure. It was done before i bought the car.
well there is a thread I wrote, about making 300rwkws.
I used a GT3037 turbo. NIce little unit, not laggy either.
Do a search for "My 300rwkw adventures" and put me as the member. It should pop up and give you everything you will need.
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
