i have a problem with my rb25 atm ..when just crusing if i back my foot of the gas slightly thr revs will rise slightly ,say im doing a solid 2900rpm i back off it will go up to 3100 before it goes down...also some times it randomly doesnt wanna go past 4500 rpm as easy as i would like but other times it is sweet as ..any one know what could be the prob ..thanks
https://www.sau.com.au/forums/topic/250554-what-could-thid-be/
hmmm
thats a bit different, the only thing i can think of is if ur backing off and clutching at the same time you may be clutching just a slight bit before u take ur foot off and its just free reving a bit. If its doing it with no clutch and the car is actually accelerating slightly for a second when u take ur foot off then that is really weird
Ok so for example your driving along in 4th gear (manual im assuming?) at lets say 60km/h and u remove your foot from the accelerator and the revs rise a little before going down?
try driving it hard say for exmple full throttle up to 4-5k rpm then take ur foot off and see if it does it
if it doesnt then i suspect its your aac valve perhaps otherwise...... hmmm
stock ecu?
if so try reseting that, its a weird problem your having and im just suggesting that as a general thing, It may be as easy as that but yeh your problem seems rather weird
does it happen lower in the rev range? whats your idle set at?
i know on a cold day when the auto-choke is active on mine, i can cruise along at about 5-10ks an hour without putting my foot on the accelerator. has been doing it since i had a 100,000 service on it, am guessing its becuase they cleaned the AAC valve and set the idle to 950RPM (instead of 650RPM stock NA)
either way, i find it handy, but dont get your backoff issue. could be to do with something around the throttle control/body/butterfly
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
