$150
i know nothing about it/audio stuff. so take it away.
as far as i can tell its in as new condition.
this is what fusion say about it.
CEA 2006 Rated
2 Ohm Stable MOSFET Amplifier Design
CEA 2006 Amplifier Power Standard Compliant
FUSION Regulated Amplifier Technology (F.R.A.T)
FUSION Intercooled Semi-conductor Technology (F.I.S.T)
FUTRANZ Efficient Heat Sink Transfer Technology
Gold Plated 4 gauge Power and Ground Connections
Gold Plated Audio Input and Output Connections
Gold Plated RCA Output for Multi-purpose installations
Compatible with FUSION bass control remote
Product Specifications
Bandwidth 10Hz – 40kHz
Signal to Noise >95dB
Fuse Rating 2 x 25A
Separation >60dB
Input Sensitivity 300mV-8V
LP Variable Crossover 40 Hz – 160Hz @ 12 dB / octave
HP Variable Crossover 40 Hz – 600Hz @ 12 dB / octave
Variable Bass Boost 0 - + 18dB @ 45Hz
Variable Sub Sonic Filter 20 Hz – 55Hz @ 18dB / octave
Input Impedance 20KΩ
Damping Factor >200
T.H.D 0.05%
Dimensions D 57.5mm L 330mm H 220mm
CEA 2006 Compliant Amplifier Ratings
12.6 Volt Power Output Specifications
50 WRMS per Channel @ 4 Ohms and ≤ 1% THD+N
75 WRMS per Channel @ 2 Ohms and ≤ 1% THD+N
150 WRMS Bridged Channels @ 4 Ohms and ≤ 1% THD+N
Edited by ted180
https://www.sau.com.au/forums/topic/250555-safusion-fe504-amp/
