Take wheel off, take brake pads out, undo bolts on caliper, undo bolts of rotor, rotor will come straight off
what rotor bolts?? it dont have that big 36 mm nut like 33's have
Edited by gazza750
Ok it must be connected somehow, i don't know how else a rotor would be held onto the axle. Got a pic?
On my MR30, the rotor is part of the hub, remove the caliper, remove center nut (axle nut), it all comes off in on piece
On my 240K, the rotor is bolted on to the hub, remove caliper, remove center nut (axle nut), it all comes off, undo 4 bolts holding rotor onto the hub (on the inside of the hub), give it a good smack with a big block of wood.
I don't know if the HR30 is the same,
Nigel
Edited by noddle
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
