Very clean stock standard Series 1 with turbo timer.
Price pending but looks like approx 8K neg..
Contact: David S
Mobile: 0410 073 931
p.s: Will sell as whole only.
p.s.s: Unfortuantely this is all the information that I've been given.
I have posted this for David as he doesn't have net access, so
please contact him for any furhter questions relating to car/price.
Thanks
EDIT: Ive been told its a 96 model and was the last of the series 1
https://www.sau.com.au/forums/topic/25081-r33-gtst-written-off/
my advice is just to sell all things like doors, etc separately.
Otherwise some entreprenur will pick up the whole car, sell all the bits off it and end up making twice the price they paid for it complete.
Its just whether he wants to deal with the hassle.
