  • Replies 124
Im not sure. The only thing he said was something about the ECU going back to the battery and not the alternator. The only problem i have is if i winge too much he could easily change a few figures in the ecu and either detune it, or make it a time bomb waiting to happen. I think this time as times in the past when i have been burnt by workshops is to just pay it and never go there again.
Here is the dyno sheets that $1000 of tuning got me.
And it's only running 12psi. They said they pushed the boost up but it didn't make much more power. Does this sound like B/S? The engine has forgies in it and the turbo is bigger than stock with a steel wheel. I have pushed it to 16 psi and it felt like it had much more power than 12psi. And i dont know where they pulled the 168.9kw run out off. it was making 200kw when i got there... The usuall tricks to make the figures look better. So please people that see dyno sheets all the time please tell me what you think about these.
best to list the parts you've got in there and what tune you're running on.
It's one of those things where I think the workshop will be able to justify the bill because of the amount of time spent on your car. But that's why the advice has been to take it to another workshop, because these guys may lack the experience. It could be that they took 5 hours to find a problem that would take another workshop 1 hour. So best to part ways me thinks.
Yea i will NEVER EVER go back to these muppets. I do understand that time is money and yea they could justify there time and the cost. The thing that has pissed me off the most is there was no communication!!! They kept telling me that they will look after me and that it wont cost much at all.
The mods are FMIC, electronic boost controller, turbo has been rebuilt and made bigger and a steel wheel. I think it's rated at 450hp now. bigger fuel pump, haltech interceptor. engine rebuilt with forgies.
Well i paid the bill and picked up the car. So pissed off at the company. But i have to admit the car does run well. Not $2200 worth but it is good. And i found out that dyno time was charged at around $235 and hour
So $235 per hr and they couldnt even find that it had a bad earth proplem???
Do any of you boy's/girl's get pre dyno check's done before your tune???
We do battery, power to coil, power to fuel pump and fuel flow/pressure check's before every run and add it into the bill.
Best to sort these issue's out before you waste 20-30min's to strap it down and end up with no result.
Bet there isnt a person on this site who would not have wasted days trying to find that problem. How many people who have a car that suddenly drops 150kw have a first thorght of "I wonder if the the battery terminal did it"???? The guy probably didnt charge you for half the time he wasted on it trying to diagnose someones else's substandard work. Dont forget that you now have a car that is running sweet and has had everthing on it checked and double checked. Regardless of wether you planned to spent that money or not its not wasted!! Another point to remember is if you change workshops now there is a real good chance that the first time you have a problem your NEW!! workshop will be charging you AGAIN!! to check things that you just paid this guy to do. He on the other hand will be know your car very well. No I do not have a workshop and dont know the car or the workshop from this thread. Just my two cents on a subject where it seems that most of the advise given to you is based on other people knowing everthing and your mechanic supposedly knowing nothing. Niether of these two things are true so try not to judge too unfairly.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
