i have recently run a big end on my 26 and because i am a cheap bastard, i have decided to bin the 26 bottom end and replace it with a 30. i was not planing on changing anything but have noticed that there is only one oil return hole in the sump and the 26 has two, one for each turbo, should i bother drill and tapping another one into the sump, or maybe installing a 't' into the 30 drain hole and run both oil return lines into it, or just buy a single turbo inlet manifold and a turbo and do away with the twins.
if i go single, what turbos have people used, i would rather a bit more mid range, than a big punch at the end.
will the standard n1 twin 26 turbos run out of puff in the high rev range?
any input will be greatly appreciated, thank you.
Edited by brada31ke70
https://www.sau.com.au/forums/topic/250923-twin-26-turbos-on-a-30/
If running a standard RB30 bottom end, I'd suggest spinning it to only about 7000RPM. 7500RPM max.
The N1 turbos flow enough to make 320 odd AWKW on a 26, drop boost a few PSi, and with lower rev limit you'll make "less" power, but you should pull the same torque. hence, a less stressed engine.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
