Got woken up by my mechanic with bad news today - the catch can, a 700mL coke bottle, is half full of oil. :D 18 months ago it was just slightly misty, so something may have happened internally since then. I haven't felt anything wrong with its performance, but apparently broken ring lands can be silent killers like that.
A compression test is being done to find out whats going on. Everyone think positive thoughts! :)
Gradenko can't afford a rebuild without a job. Hire him!
https://www.sau.com.au/forums/topic/25094-my-coke-bottle-is-half-full/
  • Replies 41
LOL - fair call on that one. :)
My ring lands on number 3 are on their way out, but not as bad as yours to throw out a heap of oil like that.
Maybe an rb25/30 conversion is on the cards for you? Would probably be cheaper than rebuilding the 25.. :D
I know exactly what you mean. If you want some help to do the conversion, let me know cause I'm interested in doing the same. :)
mmmm rb 25/30.. lotsa low down torque with good boosted high end.. :D
Compression test came back even, all cylinders between 125 and 130. Its lower than optimum, but that can be put down to normal wear and tear. Just glad none of the cylinders are dead :P.
The car hasn't been used in 4-5wks, so the battery wouldn't be at full charge and cylinder walls may be too dry to seal well. Could be a reason for low readings, yeah?
GTS-t VSPEC, leak down test would tell me more, but its generally the next step after a compression test, so one had to be done anyway. I'm fairly sure what leakage I have can be put down to rings.
adam 32, thats the plan :P.
Originally posted by Boostzor
Hmmmmm, causes.......oh yeh, maybe its all the floggin its gotten from u and jeff:uh-huh:
What floggin?:P And it was jashs wife's, so I think its been treated well (although jeff tells me she has speed in her blood).
RedLineGTR, go whore in your own state.:bonk:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
