  • Replies 41
Biatches please.. :P
Gradenko - mine are all between 150 and 155 with the exception of number three which is 130, which was considered low. All of yours down at this level don't sound too good to me..
Go the conversion! :P
Adam - thats my plan too.. :)
The thing is I can blame the low readings on an uncharged battery and unlubruicated cylinder walls. Compression test results can be random like that.
I'll see if Steve thinks the dyno reading tomorrow is about average or too low.
Adam, Not necessarily true, alot of people don't keep cranking them, they stop at 4 cranks, if there is any major difference then you know the compression is low, so actually readings can be misleading, it is the variation in readings that is important.
Originally posted by adam 32
compression test aside, 350ml of oil has come from somewhere...
350mL of oil in vapour after 20L of oil has passed through it (4 oil changes). Could that be classed as normal? Macka has that filter on his breather, does he find a layer of oil coating his bonnet lining?
The catch can mod is damn useful. All this oil would be lining the inside of my intercooler and clogging the idle solenoid otherwise.
Pretty much the first time its been checked, yeah.
Just got a call from Danny, it pulled 280rwhp (shootout) after tuning on SST's rollers with no sign of detonation. The front facing plenum mod is a success! :). 280rwhp isn't anthing special, but its about all a 5 knob s-afc is going to let us safely extract.
Originally posted by zanda
maybe get a real catch can without coke residue in it! :)
Careful, dont knock his coke bottle, he's awfully proud of it.
Half full eh, so when a you going to go the twin coke bottle mod?
lol @ zanda
deesh, the coke bottle rocks! Its the kind of quality engineering we've come to expect from Coca Cola Corp. Afterall, if it can hold concrete etching coke for months at end, whats a little luke warm oil? :)
Twin coke bottle mod is coming. The hose attaching the left and right breathers together has a crack in it, so I may as well run new piping from the left breather to a bottle of its own :)
BTW, test drove the car today and its insanity peppers. Modified plenum mod is highly reconmended for all you fmic'ers.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
