go to supercheap auto, and grab a bendy magnet. Its a long flexible device with a powerful magnet on the end.
Poke that down there and it will grab it.
Just recently when replacing my airfilter, I dropped a nut down the afm into the mouth of the turbo. Instead of pulling the whole intake off, and possibly the turbo, I blindly shoved my bendy magnet down there, and out came the nut.
Edited by The Mafia
https://www.sau.com.au/forums/topic/251011-help-bad/
hey guys,
as you may of read my other post about that thing from the thermostat in the way of the welsh plug to get to the welsh plug, well i got that out today with ease, i was like sweet i can get to the welsh plug which went to the left of the hole,
so heres where my problem started,
as it was to the left of the hole, i took the welsh plug next to it out (to the left) and tried to reach across, i couldnt feel anything, so i tried going through the hole it was ment to come out, i felt it with the tip of my finger then it must of dropped down or something,
so now, i can reach it from any hole, its a copper welsh plug, can i just leave it in there? or how can i get it out?
i would be willing to pay some1 $30-40 an hour (obviously there would be a point i wont pay anymore if its still in there) if they could come round and do it for me because im about to burn this car,
any info would be good,
Thanks JV
Edited by sly32
https://www.sau.com.au/forums/topic/251011-help-bad/#findComment-4346460
Stewart Little would work for $30-40 and hour.
I wouldn't use blue tack, but I would use grease!!!
are u tacking the piss or is that some1 on this site? anyways ive found a mechanic that will come round to my house and work on the car with me, he was asking heaps of questions about it and thinks he will be able to get it easy if i cant,
blue tack would fall off and u need a bit of pressure to get it to stick,
grease??? wtf whats that going to do?
gurnie (spelling), take 1 hose off and shoot it out the other? that doesnt make sense at all really,
but i will be trying the claw thing, fingers crossed i can get it, the mechanic said depending where it is you can leave it, just cant be near the water pump, so im thinking i will have to get it out lol,
will update later,
JV
https://www.sau.com.au/forums/topic/251011-help-bad/#findComment-4349034
Stewart Little is the mouse, yeah I was kidding.
The grease idea works, you use a bit of wire or some such with a small flat on it, you load the flat up with grease and then go fishing. If you lob it on the copper bit it will stick to the grease and then you can carefully retrieve it. I've done it before for various jobs and it works.
The best bit is that any grease you loose won't do any harm anyway [unlike blue tack].
https://www.sau.com.au/forums/topic/251011-help-bad/#findComment-4349209
will update later,
JV
Why not use some duct tape, a vacuum cleaner, and a tube that is small enough to feed down to where this thing is but either big enough to suck it up, or with a tip that is likely to suction the item onto it and hold it.
Duct tape the smaller pipe to the end of your vacuum tube and away you go.
Of course you'd need to drain any liquids out first.
https://www.sau.com.au/forums/topic/251011-help-bad/#findComment-4349272
somebody call Macguyver already
Macguyver would ground the comp cover up into filings and then set it alight to make a bomb and 'blow that sucker out'.
The vacuum cleaner idea is a good one [i've used it like that toclean out stud holes etc].
https://www.sau.com.au/forums/topic/251011-help-bad/#findComment-4350389
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
