Hey all have the following parts up for sale
Pretty much brand new 25mm Bolt on spacers, 5x114.3 used one to see how my wheel sits thats it
its a pair, also included are the hub rings for the wheels
$150
R33 S2 Door trims, driver and passnger door
Immac condition, have no use for them
$100
R33 Dashmat, Black in color Brand new
$50
R33 S2 GTS GTST suspension
Standard, standard springs, no use for them
$100
JL Audio Tube Sub, perfect for just behind the seat in your daily driver
$75
Cadence 4Ch Amp, has tiny scratch on cover, pretty sure its 4x50w rms, works fine
$75
R33/S14/S15 Rear Camber arms, Toe Arms, Traction Arms, Complete set, Brand new unfitted, They are chrome, traction rods the chrome peeled a bit near the welding, could just respray them, got them from the usa, changed my mind and not going to mod my car further
$250
Whiteline Adjustable sway bar R33 Front, Complete in great condition
$100
Also have a brand new interior from the Group buy guy, is a Peachy color consisting of the following
Front and rear seat wrinkled
Gear boot, Handbrake boot, centre glovebox, and 30m of extra material, enough to do the whole door trims, dash, console, parcel shelf
Its an EOI atm and looking at offers
Will get pics up asap.....
Please dont hesitate to pm me or call me on 0430 129 882, Mario is my name
In Sydney
Edited by Cro_boy_Mario
Also have the following
Cusco Front Lower Brace in Immaculate condition $100
Cusco Adjustable Front Castor Rods in Immaculate condition $150
Will Take Reasonable offers
BUMP
JL Audio tube sub $50
Cadence 4Ch $50
Standard Suspension $50
Door Trims $75
Rear Adjustable Arm set $260 POSTED
Cusco Adjustable Front Castor arms & Front Lower Brace $260 POSTED
Cusco Adjustable Front Brace
Cusco R33 Adjustable Front Castor Rods
$260 Posted
25mm 5x114.3 Spacers, including Nuts and Hub Rings,
$160 Posted
I will do all the adjustable suspension parts and cusco items for $500 Posted....
sent u an offer on that sway bar....i'll PM u with my phone number just msg me and i'll call u. i'll be out all day so might be able to come by for the sway bar
  • 3 months later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
