Hi Guys,
I have a Mongoose m80G in my r33 and randomly the car wont acknowledge the remote. The remote works, the light flashes, but the car doest arm or disarm which is abviously a real bloody dilema! Doesnt matter whether im point blank right next to or infront of the car it can take 10mins before it wants to work.
95% of the time it works, but this 5% is incredibly annoying!
If the battery were on its way out, then why does the light still illuminate? And why does it work from 20 meters away at other times? Battery as the answer doesnt make sense in this scenario.
Well it does make sense because it requires significantly less power to turn on the tiny LED on the remote than it does to send a signal to the receiver in the car to disarm the alarm.
As Chris said, do you have the other remote? Does it do the same thing?
Exactly, not mention batteries are fickle creatures at the best of times. They're not some energy bucket that drains with perfect voltage from top to bottom, but a chemical reaction that gets more and more sporadic the lower in charge (less chemicals to react) they go. Not to mention the effect of heat and other things.
The effect of heat.... hmm interesting! Might be something there...
Reason why batteries doesnt sound right to me, and im not arguing ill get them replaced to be safe, is i can stand 20m away and arm then disarm over and over and over to my hearts content 95% of the time. Anyway, replace batteries and see how she goes!!
*Shrugs* heat isn't that big a deal though.
It's possible it's a problem contact on the switch of the remote. But, given what you've described, it's far more likely to just be the battery. If the LED is lighting up, and nothing is happening, then the switch contacts aren't the issue and you can put pretty good money on it being the battery.
I have same problem..... from what ive figured out and have heard is that something causes interference with the remote signal to your alarm....
have you noticed that it always happens in the same spots??
With me it never works in the same spot/section of the coles car park i go to LoL!!
i doubt its the battery but then again could be weak signal due to battery running out
but i tried changing battery once and went to the dreaded part of the car part and yet again no worky!! ;)
Hmm check the antenna be sure its connected to the wire properly on the brain if its mounted on the floor your range is smaller than if its mounted on the dash (Dont tell us where it is), Try the second remote if you still have one.
but i tried changing battery once and went to the dreaded part of the car part and yet again no worky!! :)
hey yeah it could just be this. With my mums old car(96' Ford Tauras) it would'nt work In front of a shop which had a big powerbox thing on a pole out front but it worked everywhere else.
Hi mate,
Its true it could be the remote battery but just try the other spare remote, if this doesnt work as well chances are its more a problem with the system then the remotes, as chance of both remotes not work as same time because of the battery is slim.
I am more inclined to think that its more to do with the system earth. If after driving and hitting bumps etc the earth may move depending on where is was mount, causing the system not to respond. If this is the case though the LED on the dash would not be flashing.
If the dash LED is still flashing and your remotes work fine ie their lights come on when pushed, chances are its some sort of interferance or it may be that the units antenna is not working consistantly. If this is so, then yes it maybe effect by the heat in the car.
If you keep having problems give me a call I own Platinum Car Security, I can have a look at it for you if your in the Sydney area. Otherwise may be able to advise you over the phone
Kind Regards,
Daniel Gardener
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
