Fitted some Nitto NT555 Extreme ZR 255 35 18 tyres today. I am absolutely blown away with the traction these tyres have given me. I can only just spin the tyres in first( not slipping the clutch ) and every other gear is TRACTION CITY.
To give you an idea on why my excitment has reached such a pinical. I recenly purchased some 18 inch AVS mags that came with some 275 Dunlop LE MANS fitted to the back. I have had these tyres before and haven't gained much respect for them. Fistly upon measurement they showed there true colours and proved to be only 245 wide....what a crock!!! I had megga wheel spin in 1st, 2nd and sometimes third. This lead to almost new tyres lasting 6 weeks..... So after I turned them to slicks I went down to JMS were I confronted DENZO. " I want some tyres that will actualy grip" After parting with $320, I left with a pair of semi-slick AVS( Yokohama ) 245 40 18's. As Denzo said "these will give you sick traction or I'll give you your money back"! I left with high hopes. After having the tyres fitted.....and one rim scratched grrrrrr, I left. Well after almost putting my car into a gutter going around a roundabout ,with 0% throttle. I figured something was amiss. I confrounted Denzo with my ice skatting antics......"they need more heat!, do a burnout and give them ago" I found a side road and proceeded to warm them up. Yep he was right, I had sight wheelspin in second only. BUT what a joke, any other time apart from straight after a burnout they gripped like...........hmmmn slipped like I had just driven through an oil patch. I returned to JMS with the news,( didn't believe me at first when I said I was getting wheel spin in 4th) and Danni agreed to source some more tyres. To my delight he showed me round the back the next day to some practicaly new Nitto's.....he even paid for the fitting !! If that wasn't enough to put me in a good mood, they stick to the road like Sh!t to a blanket !!!!! I have had 23 cars most turbo, and have never ever come across tyres this good.
https://www.sau.com.au/forums/topic/25117-nittos-made-me-speechless/
Boostd: How many rwkw are you making?
Unless I "drop" my clutch from 2000rpm or higher I -cannot- make the rear tyres spin. The only way to make them spin is to put on heaps of steering lock and boot it out of an intersection from a standing start and even then its just squeeling not even getting the arse out. Wet weather I can make the rears spin obviously.
This is on 225/50/16 Michelin Preceda's worth $230ea fitted with 203rwkw.
These Nitto's sound like they are the ants pants whilst coming at a huge price.
Originally posted by franks
benm, you need some torque mate.
I need a PowerFC thats what I need.
266rwkw is understandable for needing something abit better than the standard road tyre.
Franks I woulda thought that a rolling start would be less stressful on tyres because most of the area where traction would be lost (dropping the clutch and physically beginning to move the car) is taken out of the equation.
Have all you guys got the Dr_Drift Pineapples installed, if not i'd highly recommend them for extra rear end grip.
$320 for a pair of 18" Nittos is damned cheap. Aren't they worth like double that, EACH? I'm sure I've seen some prices somewhere and they were like $500-600 each or more.
BOOSTD, keep us posted about how long they last, I was also under the impression that they don't last very long (hence mostly used for drag racing only).
Originally posted by benm
I guess it just depends on how you drive the car.
40yr old parent = probably 25,000km
20yr old car enthusiast = problably 10,000km of street racing
Hmmm.... Well, if you go by this, BOOSTD = 5,000 - 10,000kms! :) No one else I know kills tyres in 6 weeks!
I'll run and hide now! :) lol
Man that's a pretty good deal for a pair of Nittos. I saw them for $495 for 1, 245/45/17.
They must be sick on the road. But the wearing wouldn't be the best, but than again who cares about wearing when you got so much grip!! hehe
Are they any good on the wet tho??
Well have fun with them anyway before you have to change them.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
