  • Replies 176
Posted Images
Longtime, no post! for me anyways.
Will be there with bells on, and a camera >_<
what time does this thing kickoff? I wanna get down there pretty much as soon as most cars are there cos i got things on later in the arvo. Someone said to me that spectators rock up about 10am?
10am sounds about right but any other info would be great thanks. :/
Hey Chef, You might want to make sure Matty brings his Patrol on Sunday to tow all the bogged cars off the grass :)
i'll bring my snatch straps
pity i didnt hav my winch...........would b able to do the "recovery" from on anzac highway hahaha
Pity the non-AWD/4WD vehicles :/
I thought it was supposed to be a charity event, we were going to put in 6 cars R32,R33 type M,R34 Nismo spec,R32 GTR and a 2004 V35 all Stock but we got turned down shame that, when its supposed to me a charity event we were there last year it was a great day BBQ meet other import owners the V35 got accepted but he doesn't want to go on is own he just got is V35 from us it would if been is 1st time out Oh well never mine...
It's a charity event that 1) was already at full capacity before you entered, 2) already had 39 Skylines entered ahead of you, and you wanted another 6 to attend and 3) the V35 that was accepted was the only one of the six you sent the committee a photo of.
As was mentioned in the email you received, it's nothing personal, you just left your run a little too late. If you're concerned about your entry money not going to charity, feel free to drop by on the day and donate to one of the Animal Welfare League tins located around the reserve.
hopefully the weather isnt too bad ... hopefully no sissys pull out cos they dont want to get their car wet :) .... just hoping I dont get bogged though.... sucks not having AWD :P
sounds like this is going to be bigger and better then last year.... good work Chef and the AJD committee :/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
