Few questions
Before that is it tig or mig ? Not sure, but I know little bit about this like letting it cool off and to tack a bar in place to reduce flex etc
1. We see this all the time on race cars to improve rigidity so has anyone done it? Any tips or tricks? Because I hear the chassis wi flex.
2. If we were to go to a professional to get it done what would the cost be? Say for just the front strut towers ?
3. There's a tig I've seen mentioned on an earlier post for about $560 would this be suitable.
4. If it is feasable and practical I may buy it and do my car just for fun to see what it's like, obviously you don't need much experience to spot weld inch on inch off. Would there be by probs other than flexing?
Depending on things I may be willing to help out fellow sau members but that depends on time taken to complete etc.
Let me know ta!
Edited by DaGr81
https://www.sau.com.au/forums/topic/251286-tig-welding-your-car/
hi bud.....
have you ever welded before..?? tig and mig a toatally different....if you buy a tig buy a gas regulator consumeables such as tugnsten tips nozzles and diffusers.....oh and a bottle of inert gas...argon...migs need gas aswell...or you can you a flux cored wire (gasless) just so you know you can get flux cored wire thats requirs gas too.....
inch on inch off is stiching not spot welding...
what are you hopeing to acheive?
what sort of driving do you do is it even worth the time money effort???
I see, I guess I'll be stitching then ^_^ improve rigidity for track use and I have used a welder in high school some 6 years ago, but if it helps I know I will do a quick course on it, basically just put stitches all over like strut towers etc I'll post up a few photos when I get home but yeah the whole idea is for improved rigidity and less chassis flex and flatter cornering etc willing to spend 560 on a welder to do this
ah i see...maybe it would be money better spent on good suspension , better sway bars spring shocks......etc
myabe i dont know....:D good luck with it anyways mate..i got a mig welder new off ebay for 290 delivered it works a treat....running gassless....i think it was from Geoffs Tools online store (ebay)
TIG will give u a nicer weld-presentation wise,& depending on the operator probably more penetration.
Mig is quick & easy but doesnt look as good as TIG.
& yes dont use gasless on your car it looks shitty no matter how good u r at welding.
shielded welding (gas) will alwyas give a nicer weld...and you can get a nice looking weld using gassless......dont know why everyone thinks gasless is so horrible
Hey mate tig is the go, and it will take alot more work than just the strut towers. I fyou really wont to gain something out of this you will want to weld almost every seam on the car in which case you will need to pull the windscreen out weld all the way down the join there the shotgun panels stich the underside of your car and so on, it's a big job if you want to do it propaly if your in melbourne outer east give me a pm and I'll come out and show you were you want to weld anyhow good luck....
Too bad I'm in sydney :P well I've got this rolling shell sitting in the back yard you see so I wanna slowly do all that prepare it for track fun... You think doing just the strut towers + the whole interior and boot will have any effect? Don't wanna start pulling windows out if I don't have to...
hmm just come across this thread and its exactly what i'm doing right now with my R31 skyline shell. TIG welding ALL (yes all) the seams and joins of the body. Though i'm only welding in the cabin area, as front and rear has strut braces going on. TIG is better than mig as it moulds the joins together rather than adding to them.
The only downside to welding most seams in your car, is you go through a lot of gas, and gas refills are around the $90-110 mark.
And yes, it is really easy to blow huge holes in the body if ya not careful.....practice on something first !!
I'll have to take pictures and post up my R31 body.
Few questions
Let me know ta!
ok i could write a whole page of dos and donts but short answers r
1 done 8 full cars and bits on i dont know how many cars .best trick is prep clean the surfaces back to bare metal then clean some more
seam sealer between the pannels is your worst enemy
you will only get flex if u heat the area to much
2 just the towers u say, if u do all the stripping n some prep around 350 if they have to strip ,prep,weld,seal,paint,around 1300
3 i would not use a tig i would use a mig some reasons are speed mig is much faster, n trying to tig upside down under the car is not easy
and it is easier to get the mig into tight places
tig is good for small jobs un less u have a fark off watercooled tig
4 heaps of othe problems if the prep is bad, fires ,chocking on smoke clouds , burns from boiling seam sealer splashing back at u
good prep will make a big difference
heres a few pics
More cost effective to diy, how come yours are spaced apart more than what I've seen on some map cars? Any noticeable difference in feel of the car? Rigidity? Flex?
i usually go in between spot welds as it is already welded on that spot as the name sugests.
it does make a difference but u wont notice much if the rest of your set up is lacking
if u do go to the effort then another thing u can do is around the door jams with a spot welder
new spot welds in between the factory ones
Mmm now to hunt down a mig ^_^ thanks alot for the great input guys once the funds are back up I'll start posting up pics, but first I need to add a boost cooler to my daily
i just bought a new 3 phase mig and want to sell off my gas/gasless SIP Mig if your keen.
similar to this item - http://cgi.ebay.com.au/SIP-Mig-Welder_W0QQ...106122001r15622
i payed $575 retail for it
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
