  • Replies 447
Damn, looks like I just missed out!
Don't worry about it, next group buy closing date is 7th August... quote sent, check your pm, reply to my email if pm doesn't work for you.
Next RDA Group Buy 49 order list:
- keii (payment cleared)
Update to RDA Group Buy 49 order list: (Closing 7th Aug)
- Moodles2 (payment cleared)
- 180 wanabe (waiting for payment to clear)
- BASHO (to be confirmed - for a R34 GTT clutch)
- DriftGTS (waiting for payment to clear)
- 180 wanabe (payment cleared)
quote sent...
- DriftGTS (payment cleared)
- PhilKenSebben (waiting for payment to clear)
- BASHO (waiting for payment to clear - R34 GTT clutch)
Quote sent, UnCo
- PhilKenSebben (payment cleared)
