  • Replies 447
Rianto, Just a quick note that i recieved my pads and rotors, thanks for organising another successful group buy!
To those thinking about getting EBC brake pads, I highly recommend the redstuffs and the RDA slotted rotors!
noticed some post missing since the past 2 days...
Update to RDA Group Buy 49 order list: (Closing 7th Aug)
- keii (payment cleared)
- Moodles2 (payment cleared)
- 180 wanabe (payment cleared)
- DriftGTS (payment cleared)
- PhilKenSebben (payment cleared)
- FOOLBOOST (paypal payment cleared)
- br3ndan (waiting for payment to clear)
- BASHO (waiting for payment to clear - R34 GTT clutch)
matt, check your pm. what car is it for?
- br3ndan (payment cleared)
- BASHO (payment cleared - For R34 GTT Clutch kit)
Rianto - When this one is done - can you start a new thread mate?
Its easier for Admin to keep track as there have been some wayward GB's over the past 6 months so we are trying to clean up the section with a bit of policing and more closer/strict rules.
So once the GB is over (as per the start/end date), just start another thread and i will come along and close the previous ones.
Thanks for the GB's, i've left you feedback from my rotor purchase late last year too, i forgot to do it lol :angry:
no problems :devil:
Hi, Can you please let me know how much rotors and red pads are. I have a 2004 V35 350GT. Also are you able to get red calipers?
Delivery would be to Flinders, NSW 2529.
Thanks.
Hi Adrian,
I don't sell calipers, sorry - you could either get a can of heat resistant paint and paint your caliper, or browse the net for a set of red calipers.
Does your 2004 V35 have brembo calipers?
Let me know - cheers.
- shnoog (payment cleared)
- Chi100188 (payment cleared)
Hi Adrian,
Hi, I dont think they are Brembo. They are just a charcoal/silver colour. Cannot see any branding on them.
Hope that helps.
Adrian
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
