hey guys,
picked up a highflow for a decent price so chucked it on around november last year. had it freshened up with new seals and new compressor wheel as old one was eroded . took it for a tune and set the bleed valve to 12 psi and it was boost creeping to 17 psi at 7000 rpm. was running a 2 1/2 inch split pulse dump pipe into a nismo 3" font pipe, had read on forum that the split pulse dumps caused boost creep so modded my split dump and changed it to a bell mouth. chucked it back on dyno and still going to 17psi. pulled off turbo again and machined out waste gate from 24mm to 28mm (exhaust wheel hole size off 52mm) this was a 36% increase in surface area. putt the turbo back on and still went to 17 psi. i have finally taken off the 2 1/2 " dump and front and fitted a 3" front dump pipe hoping to drop the pressure in the exhaust and get better flow but alas it is still doing it. cant think of anything else that can cause the problem. got in contact with the guy who had it before and he had it running on 14psi ok. any ideas anyone!!!!!!!!
modds as follows
safc2
stock injectors
nismo fuel reg
walbro fuel pump
full 3" exhaust
FMIC
thanks
Eric
Edited by Pal
https://www.sau.com.au/forums/topic/251369-overboosting-problem/
Hey bud, was it doing this before you put the turbo on?
I had a similar issue with my stock turbo, i had a turbotech boost tap and it would creep up to around 15psi. I finally pulled it off and put the stock solenoid on and it holds boost fine..
Where have you tee'd off the tap? tried a differend tap? u using the same diameter hoses??
i had no problems with the stock turbo, i had it set to 12 and would drop back to 10, i am using a GFB bleed valve, i removed the bleed valve and run a straight through hose so it would go to wastegate pressure of 7 psi but is still going to 17 only a bit slower. not sure if a EBC will make a difference. using standard tapping point
Edited by Pal
When it starts to creep, do you actually FEEL the extra power? or does it go no where, ie no extra pull? Get what i mean?
Just a wild suggestion but have you checked your base timing? i had a very similar thing where my timing was retarded by 3 degrees.. set it to 15 and it helped with the creep issue ALOT.
does your car have a stock solenoid?? if so try running through there and see if it creeps??
Do you have a cat? After i took my cat out the boost went from holding perfectly at 12psi to creaping over 14 and thats with one of the best boost controllers you can get. But after playing round with the gain setting its all good again. So my advice is to get a good model EBC and set it up right.
I reckon you have a split in one of the hoses, acting like a bleed valve. Check them all for splits / holes.
I had(have) the same problem with my std turbo, i had a big long post written but my computer failed on me , so ill keep this one a lil shorter :cool: . i put a op6 housing onto my r33 s2 turbo after having massive trouble with boost spike. as i dissasembled the turbo to fit tho new rear housing i noticed that the actator shaft fouls heavily on the side of the diaphram and has a fair bit of sideways pressure on the wastegate flap. Im in the process of modifying it atm , ill let you know if it does anything :yes:
NOTE: The turbo was/is assembed correctly , if i moved the housing any further around the inlet would foul on the exh manifold.
Edited by toffy
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
