  • Replies 287
Posted Images
Ok here's the run down,
I spoke to a few guy's from the Austin 7's club about the modern Reg' day on Sunday as the max' temp is supposed to be 25. Normally the entry forms have to be in by Wednesday but they will let us enter on the day we just have to be there by 8:30am, i'll give them a call tomorrow with rought numbers just so they know how many extras are coming .
If you read Chad's link you will know most of this;
You have the have a road worthy car (Street Registered) Car, you must have a blue triangle to show the location of the battery, you must have a rear tow hook (If you are running the factory rear bar you will have this), you need an extinguisher (at least 900g) and a helmet.
As for the day licence I will find out and get back to you all tomorrow.
As for track time i have been told by people who have entered this event previously that it compares to a track day. The first session is short and they gradually get long throughout the day until the last session were you will be on the track for around 25 minutes.
Im pretty keen on this still, I don't have a cams licence and im not a member of a car club, so let me know what you can do :)
when is the next open track day, anyone know?
id like to have the dates as i would like to attend few upcoming ones and can prepare in time.
CARS & KARTS
Saturday 7th February
Saturday 4th April
Saturday 16th May
Saturday 27th June
Saturday 1st August
Saturday 5th September
Saturday 28th November
Well boys and girls, the GTR is trailered up and ready to go. Gonna have to keep a keen eye on the times, but tomorrow will serve as a shakedown on the new sus and setup for next sunday (porsche club super sprint). Usual meeting spot - LEAVING at 7 am (ie get there a few minutes early for the hearty breakfast!). Dale - leave earlier, it is not 5 minutes to everywhere in Adelaide from your place........
Well i just got home. Had a ball. Weather was a killer in the morning with water temps around 100 degrees.
The Cool change came around 1.30 and dropped water temp around 10 degrees.
Lex had boost issues so he only done 4 full laps. After the 1.30 sessions i was the only one on the track.
And yes i did spin, yes i got some 4wheel drift hehe.
cant wait to do it again.
My car is almost ready, just have to mount the fire extinguisher and im good to go, will see you boys just before 7 :P
Good to hear that all went well Luke, Cant wait till we can all go out there together :thumbsup:
thanks for that! will definitely be out 4th april then. anyone ran auto trans on the track today?
CARS & KARTS
Saturday 4th April
Saturday 16th May
Saturday 27th June
Saturday 1st August
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
