  • Replies 287
Posted Images
Well that was a fun day, even though it wasn't the actual day that we were originally aiming for I didn't mind the 5 lap sessions. The way my oil temp was rising I wouldn't have been able to do much more that that anyway.
Although I only went out there for some track time, after the second session I was leading the Modern Reg' part of the day so I decided to actually try any have a crack at getting a good modern reg' place. The next session I tripled my points for the day though and took myself down to third place then after a reasonable 4th session ended up with a second place for the day.
Started off doing 1:26/27's and by the end of the day was averaging 1:25's with a best of 1:24.73, not bad considering it was my first time to Mallala and was on street tyres.
Here's the days results;
Practice
1st Session
2nd Session
3rd Session
4th Session
Fixed
Edited by D_Stirls
hey Dale, you messed up that last session, its session 3 again.
Well done on the second place :D I wouldn't mind going to one of these again and giving it a decent go at getting consistent times.
Ok last few pics where a little large!
that red clubman is everyones favourite salesman from redline :thumbsup: but to his credit that machine was pretty awesome, shoulda heard the
sound the engine made (hiabusa) nearly wet myself!
ah cool old school user low post count = when he says something it counts
So true steve, If it wasnt for "Who" id have no interest in turbo nissans. Still remember when I was 15 and I was scared shitless by his converted turbo pulsar.
I was going to come participate Sunday, but didn't have any mountings for a fire extinguisher, the people who did go how and wwhere did you have your fire extuighsers mounted/secured?
Mine is mounted behind the passenger seat, where the back seat would be. It should be in a spot that is easy to reach.
Looks like I wasn't out at this day - but trust me I was there! It was a good chance to shakedown the GTR for the impending Porsche Super Sprint day I've entered this weekend. Probably a good thing I did too - blew a brake line on the pit straight just like the winfield gtr did on its debut!! Was a little difficult to pick the pace to ensure a >1:20 lap - and I failed at least once (black flagged!) but once I got into it it was great fun. Just braking early and no boost plus slowing on the start finish straight until over the line did it. Recommend these days to anyone and anycar - the dial your own lap time means laptimes don't matter, consistency is what counts.
Can't wait for Sunday now - fixing the brake problem at the moment, and a little oil cooler setup mod to help with the temp control and I'll be out. Oh - and you can do parade (passenger) laps at the porsche days.........shall we start the bidding???? :(
Hey Andrew, If your gonna take a passenger i would suggest lining the passenger seat in plastic for the seats protection :P
Edited by DSTROY
Here's some of you Andrew, it was hard for my girlfriend to get a good pic cos your car was just way to fast :)
i cant wait for the next one now. Hopfully get some new tyres and pads and should be set. woo
i recommend qfm a1rm pads... they're really good all round, cold or hot you wont feel the diff, very consistent pedal feel and they seem to last a long ass time too.
GSL rallysport is doing a half price rears deal which means front and rears for $191... delivered. I cant say personally how they are compared to top brand items but ive heard that they're just as good.
Edited by tx3_90
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
