For sale rb30e series 1 block with all internals minus everything on outside $75 or swap for something that I need that is listed or interested in
Perfect for 25/30 conversion
for sale rb30et head $50 or swap for something that I need that is listed or interested in
pics up soon just want it all gone
or will swap for parts of interest let me know what you have got
Item: r33 series 1 wing
Condition: great no damage
Price: $50 or swap for something that I need that is listed or interested in
To Fit: (What car) r33
Contact: josh
Comments: removed to fit series 2 wing
will post at buyer expense
Item: r33 stock intercooler only no pipes x2
Condition: good
Price: $30 each or swap for something that I need that is listed or interested in
To Fit: (What car) r32, r33
Contact josh
Comments: only removed to fit FMIC
Front pipe
Condition: good
Price: $20 or swap for something that I need that is listed or interested in
To Fit: r33
Contact josh
Comments: removed to fit 3 inch split dump pipe
Item: exedy cushion button clutch
Age: 6 months
Condition: good
Price: $130 or swap for something that I need that is listed or interested in
To Fit: Rb gearboxes push type
Contact josh
Comments plenty of meat left on it
Will swap for r33 gtst parts like steering shroud,
the plastic bits the go from roof to floor in the middle of the car
all boot trim
parcel shelf
drivers side door trim and passenger side
handbrake rubber thing gearstick boot gear stick plastic
pretty much any interior parts let me know what you have and we can work something out
clear side indicators or smoked ones
turbo timer
stock 33 5 stud rims
pics up as soon as i find the camera cord
Edited by Turbo 33
https://www.sau.com.au/forums/topic/251613-parts-for-sale/
need it all gone just make an offer might even swap for other stuff to just let me know what you have
Contact: josh
Condition: good
Contact josh
Front pipe
Condition: good
To Fit: r33
Contact josh
Age: 6 months
Condition: good
Contact josh
all boot trim
parcel shelf
turbo timer
and r33 gtst indicator stork and the little box on the end of it
Edited by Turbo 33
https://www.sau.com.au/forums/topic/251613-parts-for-sale/#findComment-4368454
clutch sold For sale rb30e series 1 block with all internals minus everything on outside needs clean $75 or swap for something that I need that is listed or interested in
https://www.sau.com.au/forums/topic/251613-parts-for-sale/#findComment-4375473
Contact: josh
Condition: good
Contact josh
Front pipe
Condition: good
To Fit: r33
Contact josh
all boot trim
parcel shelf
turbo timer
also need an r32 rb20det wastegate in good condition but must be in perfect working order
decent battery for r33 gtst
top half of the r33 gtst plenum
https://www.sau.com.au/forums/topic/251613-parts-for-sale/#findComment-4380452
Contact: josh
Condition: good
Contact josh
Front pipe
Condition: good
To Fit: r33
Contact josh
all boot trim
parcel shelf
turbo timer
top half of the r33 gtst plenum and crossover pipe
hks ssq blow adapter so it will bolt straight on to where the on goes
aftermarket front for r33 gtst series 1 will pay extra if needed need asap something like trust or 400r or gtr style it can be a little damaged but not to much
Edited by Turbo 33
https://www.sau.com.au/forums/topic/251613-parts-for-sale/#findComment-4391373
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
