Krisppy Maccas Livo Meet Saturday February 7th @ 11am For 11:30ish Departure
  • Replies 122
I don't use my air-con, i just wind down my windows and listen to the super extreme sounds the emanate from my exhaust, that keeps me uber cool.
My car rocks to the power of 11ty bazillion and 4.
CAn i come? i dont have a skyline tho
ofcorse mate, just make sure you keep out of the pics. jk!!
i might be in depending on if i get my car back today or tomorrow morning from the engine builder - i'll need to get some run-in k's on it!
what time will you guys hit the princess hwy in sutherland i can join there.
i wanna know what time you guys gunna be around the shire aswell, i'm gunna join @ menai somewhere, or can someone call me when you a few mins before getting onto the bangor bypass????
i hope the parks are open, even if there is a heat wave its ok, i hope we all got aircon, just got mine regassed oh yea!!!
i only use my AC 1% of the time when i'm driving by myself, or on highways, or when i don't want to sweat, or when the window fogs up on a humid day. don't see the point of it unless you have wingers in the passenger seats, more you use ac, more fuel you use, less power (ever so slightly), and just another thing to service and check....
The noise the ac makes is pretty ugly especially in skylines, i'd rather hear my engine and exhust gurgling than an ugly ac sound....
i don't have the balls to take it out because i like to know that if i can't handle the heat its still there
Mates and non skylines are cool but if you act the fool you will be dropped and more than likely abused, We don't need a bad name for the club.
I drove the route last week and there will be a bit of traffic, push bike riders, and people in and around the car parks we will be using as turn around points.
That said, once we get to the final stop and park-up ill race any man/woman to the ice-cream van.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
