Yeah something like that. Depends mainly on the quality, brands and condition of the parts you buy. If i was you i would look for one with a nice free flowing exhaust, fmic, pod and aftermarket ecu tuned for the stock turbo so you can then just buy the new turbo to suit the power delivery you are after and get some injectors, AFM and a tune. Makes things a bit easier.
cheers Bennett
That seems the best way to go. What kind of exhaust should I be looking for?? size wise that would be good for running 250rwkw
Then hopefully I can just get a new turbo, injectors afm and a tune. Will keep costs down a fair bit.
Any suggestions on a turbo?? after something that spools up nice and quick. To have that responsive feel.
The way i look at it when thinking of a turbo to buy is, pick the max power you will want to run, then find all the turbos that make that much max power and then find a good comprimise between which one comes on boost earliest and cost etc. Also things like low mount, straight bolt on, internally wastegated turbos will be a lot cheaper. As for exhaust, any dump and front should be big enough, high flow cat or no cat will flow enough, and a 3.5 inch catback i would want for 250kw.
If you want bang for your buck buy an automatic GTST R33. Can easily nab one under $10k. If you really want a manual then for the sedan. You run the risk of getting a lemon of a (manual coupe) GTST for 10k and under, and R32s are simply too old for a non car savvy driver like you or I.
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
