577awKW
RB26 @ 2 BAR
GT4088R 1.06 ar Full-Race Twinscroll Mani
Kelford 280 cams Fully ported Head
Greddy intake plenum
Vipec ECU
ID1000 injectors 2 bosch 044 pumps
many more looking to upgade ignition so i can run more boost currently running superspark coils and they are not cutting it
ID1000's huh
What fuel?
It would need to be C16. He doesn't have enough injector size to make that HP on anything else
ID1000's huh
Yeah that power on e85 with 1000cc inj on an rb26 sounds a little high plus that turbo is only rated to about 680hp worth of airflow too. Must have the world most efficient engine....
Edited by rob82
Or just running 70+psi fuel pressure...?
70psi only gets them up to about 1400cc. Still not high enough for 580kw I don't think. It may do, just skeptical. There's also the little issue of two Bosch 044 pumps flowing enough fuel for that HP. Two should only JUST do 500kw on E85.
If the guy could confirm what his highest injector ms is at peak power we will definitely know if that's legit or not
Dual 044's flow around 560l/hr at 14V.
So 9333cc/min or 1500cc/min per injector in a 6 cylinder, so the pumps in this case should outflow the injectors.
I'm not sure what pumps you have tested but none we have ever seen flow what you are saying in real world results.
Bosch rate their 044 pump at 200L/hr at 5bar. This was taken straight off the Bosch website in their pump technical data PDF.
That's 3.3L/min at 12V.
They also state that the test is performed using N-Heptane which has a different viscosity and density than petrol.
Let's give them the benefit of the doubt and say 4L/min @ 14V.
At 12cc/HP on E85 that's 666hp or 497kw. Once again I'm not saying its impossible but I seriously doubt the figure is accurate. To consider the rail would need to start at a base pressure of 75psi to get about 1400cc capacity, the flow of those pumps will decrease as the pressure increases.
Then to suggest it magically makes 80kw more than the pump should handle and 55kw more than the injectors can handle.....
I don't buy it
which is also very similar to Bosch's technical data...
Not arguing that the power seems very generous for the set up, just mentioning that the dual pumps would cover the injectors easily
The second one isn't Bosch's technical data and it's 10-15% more generous in its flow figures.
The first one is just whack.
Not Bosch's data? Really? I got it from here
http://www.bosch-mot..._2776426379.pdf
http://www.bosch.com.au/content/language1/downloads/fuelpumps.pdf
Then there is discrepancy between two pumps from the same company.
They also state in the above link that they are not to be used with E85 whereas your link clearly states that it is ok.
New version maybe?
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
