Hav Tein ss super street adjustable coilovers for r34 gtt may fit series 2 r33 i think
these are 3 months old and hav only done less then 1000km
i am selling due to loss of lisence and will be in need of track coilovers i am asking $1200 serious offers only
these are great for street use due to the research to make them for aus roads
these coilovers are worth over 2k instore
ride height adjustable, 16 points of dambering, comes with spanners adjuster and more.
condition is like new, if u are after a good suspension for the streets these are the ones u r looking for.
i hav full receipts and warranty papers
genuine reason for sale
coilovers are currently on the car in south eastern suburbs melbourne
when paid for they will be taken of by my suspension fitter, also id prefer local pick up but can freight at buyers expence.
http://au.youtube.com/watch?v=9yJ4FgIAnjY
contact me on 0433696875 or email [email protected]
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
