Hya,
Just letting you westsiders
know to be cautious driving down Kings Rd/Taylors Rd - Delahey,
I was cruising along to work at 10am the other day and
I noticed the copper a few cars behind me..
I wasn't doing anything wrong at all and he got up behind
me and once I'd turned onto Taylors Rd he put the sirens on...
Mind you in my 3 years of driving my 32 I've never once been
pulled over!
He defected me for ride height for being too low,
mind you he didnt even have the measuring tool!
I was sooo pissed!
He was kind to me though :cheers:
No fine, no rwc req, just a visual inspection in 7 days at Vic Roads....
But still what a waste of time....
xx
https://www.sau.com.au/forums/topic/252121-defected-on-taylors-rd/
My cars pretty much standard
and thankfully he didnt make me late
for work by checking the whole car.... phew....
Only thing that sucks is they only gave me
7 days then my rego is suspended...
which sucks....
They must be cracking down.... :P
which sucks....
This is the time to ask for help..
Someone must have a stock set of springs in there garage.
And would fit them in Sandra's R32 to keep her on the road..
Come on i know you want to be the first to say..I can help
well i got some stock struts and springs. i don't really wanna sell em because of that exact reason of being defected and having them just in case anything happens but can lend if u really need them.
Appreciate your replies and help :P
You guys rock...
I got out the measuring tape,
the ride height is fine...
At the lowest point (front bumper)
its 120....
The problem is my muffler/pipe
its lucky to be 50! shit!
Going to an exhaust place on Wednesday to get
it fixed...
Safer for me anywayz if Id hit a bump at high speed..
(legally of course, hahaha)
cya later Sandra :P ...
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
