Hi
i have a rb25 hi flow done by SLIDING performance under 1 year ago...has 7600km siince fitted....no problems what so ever with the turbo run standard boost pressure around 7, 8 psi... ....clean and tidy still on car ...reason i am selling is i am upgrading everythign at once got power fc nismo inj, z 32, plenum and few other bits waiting to go on, so im going to get a new turbo hope to get high 200's out of it (kw) SO MY HIGH FLOW IS NOT NEEDED so if you want a good high flow pm me....these are hard to get now. V>G>C pics up tongiht when i get home....rated to around 240 -250 kw.....19 psi max
turbo will be available around the 18th january 2009 this is when i will be fitting new one
thanks
mitch
https://www.sau.com.au/forums/topic/252176-sliding-performance-rb25-hi-flow/
hi i am after $500 will throw in standard dump pipe too.....
located Mackay qld 4740
JUST TO LET YOU KNOW THIS WILL ONLY BE AVAILABLE ONCE MY TURBO ARRIVES DUE TO THE FACT I NEED THE CAR TO GET TO WORK:) PAYING FOR MY TURBO THIS THURSDAY 15TH /1/ 2009 SO 4-5 DAYS AFTER THAT DEPENDING ON DELIVERY....
CHEERS
mitch
Gday mate, I was looking for an r34 turbo to high-flow but this might be a better buy. Can you tell us how much for delivery to sydney? And i'm no mechanic, but i'm assuming that it needed a new wastegate actuator as the stock ones only 10psi max? Is that included in the package? Cheers.
CHEERS
mitch
Ok sweet as. Let me know when its available. What power are you making with it at the moment
OK Bennet has 1st dibs on this he got in 1st....YOU HAVE PM bennet if i dont hear from him its still a for sale.....might put it on ebay let you guys sort it out :P
super s13 im unsure what power im making i have not dynoed it....but it pulls hard turbo sounds great hope new one sounds same.....
atm car has greddy copy plenum hi flow coils dump and fmic....standard boost....standard ecu....going on it is 555 nismo inj power fc. z32 and Water meth kit picked it up yesturday AWESOME KIT!!!! boost cooler......
OK Bennet has 1st dibs on this he got in 1st....YOU HAVE PM bennet if i dont hear from him its still a for sale.....might put it on ebay let you guys sort it out :D
Bahahaha i see how that works. I was the first poster and he gets dibs. Nice one. What is the world coming to
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
