dude try and do a search on this for the forum.
this has been covered not long ago......
well anyways since im here ill post the differences between Series 1 and 2 of R34 GT-R
*Later models have different paint in the engine bay
*later models have black interior instead of grey like the earlier ones.
*the headlight housing is darker than the earlier ones.
*the later model R34 GT-R has a metal sheeting over the ECU
*later models have different mirror adjusting knob than the earlier ones
*Color of shift pannel are differrent (satin)
*Color of front and side market lens, early ones are yellow and later ones are white.
*different pedals
*type of radiator is different between year models
*bigger rear rotor on the later ones
*different "nissan" badge on boot/trunk in the year models
*different available std color (stopped few colors on the older one and added some new colors for the later models)
*engine oil cap changed back to R33 clicking type (not all)
*Engine number changed from start of 0 to 7 and type of font used to stamp numbers have changed but this happened some where in year 2002 (I think when nur started manufacturing)
and then theres other differences in N1, V-Spec I + II, M-spec, V-spec NUR, M-spec NUR, Z-tune etc
but
what was posted is just the standards between non GT-Rs
Look through this section, it has been covered not long ago.
Aluminium pedals
Extra two sensors on the MFD
CF bonnet
Black Interior
Bigger brakes at the rear
Different Badge on the boot lid
Engine bays are colour coded
Looks better :(
That's not entirely correct :D
The V Spec and V Spec II have the extra 2 sensors (inlet and exhaust temp) that non V Specs dont have.
The "series" 1 cars, whether it's V Spec or not, do have colour coded engine bays for yellow and red cars. Although I have suspicion that silver are also coded as well.
ANOTHER trainspotting thread!!
Stuff not already mentioned...
Hi beam bulb changed from H3 to HB3
Rear foglight tinted for S2
The seatbelt had a little arm on the pillar to hold it out for the driver – removed on series 2
Manual adjustment switch for Xenons changed to automatic levelling
Stereo headunit changed to a double DIN model
Adjustment switch for rear vision mirrors changed from square panel to round knob
Radiator changed – plastic top tanks on the S2
Space saver spare wheel rim changed from alloy (painted to look like steel) to steel
Trim inside rear bootlid deleted
Metal cover added over the rear window wiper motor inside the boot
Metal cover added over the engine management computer
Engine build plate changed from blue to silver (the Nurs were gold, just for reference…)
There's more but that can wait till later...
hey there,
lol theres a few things ive mentioned from there too.....ECU steel cover & radiator!
lol but thats a good reply!!!!!!!!!!!!!!!!!!!!!!!!
to the extent where ive cut paste what you wrote for future reference!!!
so you mentioned theres more??
DO TELL!!!!!!!!!!!!!!!!!!!!!!!!! dont be such a hold out!
:angry:
You've outdone Jamie once and for all..
nah hang on.....he hasnt yet.....
if he posts another reply with more then he has.....
the last posts all he ever said and went on about is "N1, N1 & N1"!
LOL
lol prepare to be dazzled haha
Grab handle on the driver's side was deleted in S2
Spare tyre was upgraded to a better one
Paint finish under the bonnet was improved - i.e. it was actually painted, not just a base coat
Jamie you only said the radiator was different, so I thought I should add the extra information about the top tanks :wave:
And the real kicker...
The plastic covers over the bootlid hinges were changed! Don't ask me how they changed though...
Jamie you only said the radiator was different, so I thought I should add the extra information about the top tanks :D
Mate, you are an ABSOLOUTE...................................................CHAMPION!
i would never of picked it
shiet......i guess theres SO MUCH changed between series 1 and 2...
so about that grab handle......
what......there isnt any in S2? what did they compensate for that? because ive never seen an R34 GTR with a grab handle on the drivers side..
and when you metnioned about the double din.....ive never seen a Factory double din......all have the single din and the small compartment under..???
that series 2 Brushed aluminium around the console is hella nice!
Edited by eeiko321
It's not really real aluminium though, but you already knew that hey. ;)
well i didnt think it would be....
but thats what its called anyways "brushed Aluminium"
pple use that scheme for all sorts of things ...the latest trend...fridges, furniture etc etc.
well at the end.....the series 2 console looks alot better than series 1.
I should mention the finish on the console went from what Nissan called silver to titanium...obviously not the real stuff ;)
I should clarify on the stereo, sorry I misread the Japanese. The double DIN stereo was offered as an option on the S2s. Mine has a single DIN with a dummy CD player lol, go the N1. Dodgy AM radio for me...
On the grab handle thing, I think the grip on the passenger side changed somehow, maybe a pull-out one to a solid one, if that makes sense. I haven't got a S1 to compare it to, and I can't be stuffed going out to check mine lol.
I should mention the finish on the console went from what Nissan called silver to titanium...obviously not the real stuff :laugh:
well i have yet to see an R34 with a factory double din......i dont think anyone ever bothered getting that upgrade..
although, factory sterios are rediculously expensive.... the Toyota Hiace Double DIN factory stereo was over 500$
well i guess we covered all the differences by now eh?
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
