well i should be out and about as soon as i get my car back
would be nice to catch up with everyone soon again
Goodluck and well done to you Nene as you have done a mighty job in seeing this through
keep it up and hopefully something good comes out of this for all your hard effort
  • Replies 273
Sincerely All the best...
I think the only real problem with Neils proposal was inspecting cars at events. That just makes life miserable.
As it has been in the past; police often tag along and show their presence but only come down hard/defect if people are idiots.
Completely agree with that approach but not so much the proactive approach.
Edited by TheRogue
exellent nene hope common sense prevailes and a freindly out come for all is nutted out .
good work we all apprecieate the hard work you have put into this if free sat if you need some more backup lol
cheers dean
dont know wether this is too late or the wrong guy to ask, but can we have some clarification on what is deemed "quick exeleration" and there for a strike under the hoon law?
what is quick, do they measure it in 0-60 or what?
Chris the meeting is tomorrow...
Rhys ill see how far we get in the meeting as to what we both want to happen from this... if we get to the point where we can start asking specifics ill definitely throw that one out there
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
