Mate even if someone ever stole it do you think theyd ever be able to drive it on the roads ? dont forget its the only one in the world  :headspin:
I know. Did you hear about that Eclipse that was stolen in England a few months back? It was a really rare example with a unique paint job.
The owner of the car contacted the cops, of course, but then he contacted every cruise related car forum that he knew of and spread the word about the car and showed pics of it. Sure enough about 4 days later, after numerous sightings and tip offs, a group of cruisers saw the car, followed it and gave a running commentary to the police of where it was headed. LOL. The guy got his car back, but even a week later he was being followed buy cruisers thinking that the car was still missing!
Power to the people and all that sh1te!
Have fun with the car dude.
https://www.sau.com.au/forums/topic/25261-at-last/page/2/#findComment-688817
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
