hey guys i just got some parts leftover now that i took pictures might as well post em up.
heres what i have.
LHF seat, excellent condition $70
LHF & RHF kick panels. $40
centre console $50
the centre thing after the console that holds ur headunit and climate control in $30
2 sunvisors with clips $40
ash tray from non smoker $30
rb20/rb25(series 1) ignitor $80
drivers side main window swtich $70
standard rear bar $60
gtr spoiler $100 bootlid sold right now pending pickup.
2 side mirros $50
floors mats $50 some wear from the drivers mat which is common.
parcel shelf $40 excellent condition inc the vents which is uncracked.
LHR & RHR side trims underneath the quater panel. $60. good condition.
boot trims all $50
glove box $30
trim under neath the steering area to hide all the wires and stuff $30
SKYLINE side bottom trim both $40
both a pillar trims $60
seat belts all round look brand new.
all parts are located in melbourne - springvale.
u can contact me via pm or if u want an instant response cause ill admit i get lazy someitmes to pm people just call it takes like 5 seconds to dial a number. cheers
tin - 0412-219-552
cheers and thanks for looking
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
