while the 32 and 33/34 are different senders (zircon vs titania), the difference in actual voltage output is negligable and does not affect running. Keep in mind that these o2 sensors are narrow band, they read approx:
0-0.2v = under 14:1
05v = 14.7:1
0.8-1v = over 15:1
In practice all they do is flick very rapidly between rich and lean in closed loop.
p.s again upon reserching it seems 32 sensors have diff voltages compared to 33 - 34 so i didnt head down that path
EDIT: post made irrelevant by Duncans post...
But from http://en.wikipedia.org/wiki/O2_sensor - Zirconias produce a voltage, and Titanias change their resistance, so the observation that they interoperate is unusual....
wtf is "interoperate"
lol!
so i cam or cant use them
lol!
Poor choice of word I guess http://www.thefreedictionary.com/Interoperate
Duncan has used them and they worked, but since they produce a different type of signal i'll stick with titanias and adapters. Up to you.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
