My 34gtt had a service recently and everything was ok besides front bushes. I think due to the front suspension being quite low, the front tension rod bushes are split and leaking? (obviously wear and tear also). Can anyone suggest what parts to put on to fix the problem? any rough cost estimate?
How big of a deal is this split and leaking? - just so i kno to either fix it this week or within the next few weeks...
I want to buy a set of coilovers, would that alone solve the problem? or is that different part altogether? sorry im a masive suspension noob!
Any help would be great!
Julz.
Edited by 1R34SON
Does your car pull to one side or wander over the road? Mine did with stuffed caster bushes.
With the bushes you can replace them with standard ones or go for adjustable ones. Most people go with adjustables, as this means you can increase the caster giving you more straight line stability and more camber while cornering. Whiteline, Superpro and Pedders all make adjustable caster bushes.
I paid $130 for adjustable bushes and $40 to get them press fitted, but I'm assuming you wont be doing the work yourself, so it'll be a little bit more than that when you factor in labour costs for rermoving the tension rods. Ring around and get some quotes
Btw, coilovers wont fix the problem at all - different part.
mine pulls to the left which i have been thinking is alignment, caster bushes and tension rod bushes are the same thing i presume? Thankyou for your help ill shop around then get quotes on install/fit cheers mate!
Yeah, caster bushes = tension rod bushes.
The worn bushes will be the reason it pulls to the left. If your bushes are split and leaking then obviously the cars aligment will be out.
Get the new bushes fitted and then get a wheel alignment. Should make the car alot nicer to drive.
Getting it sorted for roughly 300, 160 for bushes plus labour and another thing getting fixed included. lol mechanic showed me everything and explained bout the bushes. haha now I feel like a real idiot asking if new coilovers would fix it. Good to learn new things!
Cheers for the help!
No worries mate, seems like a fair price as well.
uhm
what exactly are the tension rod bushes leaking? =O
They are silicon filled, when they get old and start cracking the silicon starts to leak out.
Very common with the standard bushes. Whiteline bushes fixed my problem a few years ago. So much better for it.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
