hey guys just feel free to move this post if it is in whe wrong section..
OK.. hear goes. just been surfing the web a few years a go when getting my first car.. and came across a website that has many threds and posts about Mainly US people putting computers in their cars... when on the site the other day came across a skyline.. wow..
gave me an idea iv got an old laptop lying arround so i thort this mite be a kewl idea. turs out its easyer than it seams...
just a frew options what is out there
1tb hard drive if ya got the money i have a 120gb one
wireless usb stick for when you are in a wirless hot spot
wireless usb stick pay per month . telstra,, etc,,, like using the 3g network
dvd's music
gps
the list goes on
you can also hook up a digital gauges,,
but i an %80 done on this project all i need is a lcd 7'' touch screen and putty it in and i am done..
well what i am trying to ask has anyone done this and can help out on things they should of done iff the would do it again,.
if there is enough intrest i will be posting pictures of the build.. please leave ur comments bad or good as i want to know what you recon..
thanx
https://www.sau.com.au/forums/topic/253471-carputer-pc-in-my-r33/
  • Replies 95
Posted Images
post up your info and pics - I'm into PC mods etc and always have about 6 including laptops lying around and bring worked on , lots of other members will also probably be interested in getting a carPC up and running on a modest budget
i had a mate build me a small pc centarian something or other in a motex case with dvd burner usb outputs runs on 12 volts with xp media centre so it looks like a jukebox on screen. this was about 2 years ago, had it in my car ever since and love it. in my glove box is the usb hub and mini foldable keyboard and wireless 3g thing for internet so its all there and works perfectly. i decided for a mousepad built into my middle console rather than touchscreen cause when running normal windows applications such as typing on these forums or clicking around web pages on a 7inch screen makes life a little difficult.
i wish i knew about computers i could give you more details, but as far as the build goes good luck! i dont regret anything about my project, except that i've so much music and crap on there it runs a little slow. installing it wasn't hard cause my car was in parts when i did it orignally, but loads of fun. it didnt' fit in the dash or under the glovebox neatly so its in my boot, which i thought would be a pain to turn it on but i only use it when i know its a long drive coming up and therefore i turn it on before i leave the garage anyway.
I'm running a carpc in my 32 using a VoomPC-II enclosure, it's a 1.2Ghz onboard mini-ITX with 1Gb RAM, 120Gb 2.5" HDD and a slim DVD drive. PC cost about $500 to build and the touchscreen was more than the cost of the PC itself.
I have a trackball stashed to the left of the centre console for when I need to do something that is a bit hard with the touchscreen.
Don't have a keyboard in the car as there is no need, have tried a mates 3G broadband dongle and it's mint. PC is about the size of my amp and resides in the passenger footwell up against the side of the centre console, gives me easy access to DVD drive and USB ports.
It's a fairly removable setup. You could get pretty fancy if you wanted to graft things like the screen, USB ports, slot-loading DVD drive into the dash.
I use it for music (outputs to the aux port in my deck) and for diagnostics (remapped stock ecu, have consult cable permanently plugged in).
For the screen, make sure you get one with VGA input or it will look like shiet ;)
Edit: have been contemplating organising a group buy on the VoomPC setups (shipping is a killer) and I have a local supplier of 7" non-motorised in-dash VGA screens (they have others too).. not sure if there's enough interest though.
Edited by bubba
yea guys thanx for your comments.. i will be getting some pix up soon just working out the small details but will keep you all posted so far it has cost me..
$38 for the case and
$16 for cable
$32 for fans and switches
$25 For odds. solder heat shrink etc..
then the 7'' VGA touch screen about $250
so i will be trying to do it all for under $400 ( but like most of you ive got an old computer)
thanx
i have wired a the two contacts where the switch is to have a button switch all works ok..
and the laptop needs 18v so unfortuantly i can not run it off my car.. so i will be using a 150w power inverter... 12v DC IN = 240v AC out this willl be in the boot where i will run cables down to under the drivers seat..
i will have switches so i can switch
INVERTER on/off
Screen on/off
Fans on/off
computer touch switch
and main power on/off
At the moment the full start up takes 26sec and full shutdown 10. so all in all it is quite quick tho i need to hit a button. but thats all ok..
thanx mate..
will get pix up soon,,,
This is why I opted to go for an actual CarPC solution, the case came with an intelligent power supply that takes in 6-24V (IIRC) and puts out a regulated 12V, it will even handle the voltage drop while cranking so the PC won't reset!
It also waits a set time (I have it at 60sec) after the key is removed and then soft-offs the PC so you don't corrupt/damage anything.
I also have a button on the dash that acts as a power/reset button incase I need to manually shut down.. or I get pulled over with pr0n on the screen :P
I've got an AOpen mini pc (MP915-B) as a media computer hooked up to the LCD tv and it does an unreal job. It would also work very well as an in-car pc.
I bought mine off ebay for $138 posted which is friggin good considering how small it is and still has a 1.7Ghz Intel M processor, 512mb ram, 40gb hdd, usb, firewire, wifi, dvi out etc. etc.
http://www.pcstats.com/artvnl.cfm?articleID=1965
Bubba, did you get yours through MP3car.com?
Got it from mini-box.com, I got two to halve the shipping and have recently acquired the 2nd setup back (dude cbf) so will put it in the stag. Not sure whether to go for the same screen that's in the 32 or try for something bigger..
ive looked in2 doing this aswell and ive come acoss that VoomPC and it looks nice...
I got the VoomPC-2 barebones kit, very happy :) It's sturdy as and has handled being in my stiffly sprung, 2-wayed, button clutched 32 just fine :D
Is this what you bought http://www.mini-box.com/VoomPC-Enclosure;j...mp;category=101 ???
And did you just buy a screen and then install it all???
Or is there something that i am missing???
No, I got the VoomPC-2 barebones kit, then added local bought harddrive, dvd burner and ram. Screen I got from a mob over east, cost a pretty penny but I was pretty fussy - good quality, indash, single din and non-motorised..
i might be interested in a group buy, depending how tempting it is, lol, and imagine everything you could do with this, watch tv, dvd, music, web, gps navigation etc awesome
Edited by J3TR33
Guys, if you *might* be interested in a group buy, shoot me a PM with whether you'd want it in pieces/assembled/with screen and I'll start looking into prices/shipping/etc.
Installing them is pretty easy if you can install a car stereo, all you need is an earth point, a relay, a 12v feed and a switched ignition source. I went about mine in a rather epic way as I was consolidating power to pc, stereo, screen and gauges.
i am looking at a second hand package that has come up in another forum which i might buy, but if that falls through il definetly be interested in a group buy,
the only thing that concerns me, is that if it comes from america it will cost more now and shipping... due to our weak currency...
but if these can be sourced locally in aus, would be good,
most people are lazy and would just want the whole package,
MSY has good prices on normal computer parts, they might have parts for carpc as well, that might be a good start...
say if we tell them to build a xx number of car pc's to a certain spec and then buy a x number of screens...
just a thought...
I just finished installing my CarPC v3 (my third version of a CarPC over the years..) this weekend.
This latest build consists of:
* Xenarc MDT-X7000 in-dash motorized 7" vga touchscreen
* Intel D945GCLF2 Mini-ITX ATOM 330 (dual-core) motherboard/CPU combo
* 2GB DDR Memory
* Seagate Momentus 320GB 7200rpm 2.5" disk
* M2-ATX Automotive power-supply
* Automotive mini-itx case (very similar to voom case, but I dont think its a genuine voom)
* USB Wifi (Asus WL-167 802.11B/G)
* USB GPS (BU-353)
* USB 3G/HSPDA
This latest version boots a whole lot faster and seems a whole lot better than my v2 (Intel P-M 1.2ghz/1gb/30gb 4200rpm disk + 120gb 2.5" usb ext in the same case) and I'm pretty happy with it so far.
I'm using centrafuse for front-end, which I have found very reliable over the years.
I would recommend using the mp3car site as a reference for carpc information, as it can be invaluable for ironing out those weird bugs that you'll inevitably run into.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
