Ive done a bit of searching on the forum... and ive come across this....
i just fitted new boots to my handbrake and shifter to my s1 33 it is simple. just undo the screws behind the ashtray and in the centre part once you have it taken off slide it over your handbrake and flip upside down. there are clips holding it inplace just squeeze the sides and the wire will come off them then you have to bend the frame of your new one which is easy follow the old shape and slide back in
I was hoping to get a more detailed explanation on how to change it?
I heard you have to re sew the new leather boot on a wire frame? cant say ive ever sewed in my life lol!!
Any help is appreciated!
https://www.sau.com.au/forums/topic/253717-swapping-out-handbrake-leather-boot/
Undo your center console , that is the handbrake boot and the center glove box..2 screws 1 on each side beside your seat belt buckle.
take the center console off , turn it around squeeze the leather boot out of the plastic clips.
its really easy there is no need to undo the screw behind the astray.
when i did mine.. R34.. i undid the screw behind the ashtray.. removed the gear surround (had to do this anyways for gear surround).. and then reached in from there and removed the wire from the clips..
then i pulled it up and over the handbrake.. the new one i got already had a 'wire' in the boot.. i simply slid the new one over and clipped it back in
where are you getting it from? i need a handbrake boot =/
is it original or what?
Send pablo101 a PM on here. He does group buys for leather 32 and 33 skylines plus some other models. He may get some made for 34's. They are a straight swap no stitching required. The wire is already in place.
getting it off a guy on the forums
pablo101 like the person said above.
genuine nissan ones... 50 for the pair.
I suggest give him a pm... he may some some left over from last group buy.
i plan to do a DIY with pics for this so its easy for people next time :D
Seeing you got it from Pablo101, there will be no sewing required. It already has the wire in it. Just undo the screws for the centre console, pull the old boot out and push the new one in. It doesn't take long at all.
hey guys
i just swapped it out.
Very easy.
just take out the 2 nuts inside the centre console
put ur hand under it and give the hand brake boot a bit of a push and squeeze and it will come off. Dont forget to unbutton it.
slide the new one in place (over the top of the hand brake) and just mould the wire frame into the plastic clips... button it up and done! all fixed... :P
Edited by br3ndan
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
