both those coolers are built for alot higher hp than that, i doubt you would see any difference between them.
are you buying a full kit or getting custom piping made up? i'd use whichever one fits easiest/has inlet/outlet in the best spot
Edited by VB-
They just sell the core, I have to buy a piping kit. Looking at the hks kit(2in 2out)
Someone told me that the stock piping easy to broken if boost over 1.2bar
lol you've been told rubbish mate. Plenty of people running 20+ psi stock piping.
in all honesty, you don't need to change the core. stock is more than adequate.
save your money
save your money
the stock core has been demaged, that’s why have to change。。
Gt2860-5R BOOST 1.3BAR(18.2psi) will make the stock piping come loose or crack, is that ture?
Best local intercoolers for my 2c
In fact the guys there make things to match the application. Not 'bolt on boy' style. Their products are second to none.
www.are.com.au
I had one made for my old gtr, similar size to stock. However it out performed it both in power and response.
Edited by rev210
the stock core has been demaged, that's why have to change。。
Have a look at your hoses, if they look old they can crack or come loose, if they look new they should be OK.
I replaced mine with full HKS SPL kit mainly for looks though, my hoses were fine
Who told you they will crack or come loose at 1.3 Bar?
it will not come loose if the clamps are done up tight enough
Is that 2 in and 2 out pipings in the HKS SPL kit?
As i know the NISMO piping kit are exectly the same as stock piping.
How is the fittment of HKS piping kit?
They told me it's easy to happen not must be
I agree, don't worry about replacing your pipe work. I run 1.3 bar (not all the time though) and over the last 3 years I have blowen a pipe off probably 3 times. Just put a screw driver in your car to put it back on. If it is a problem it is easy to replace later anyway. As for intercoolers, mine is 600 x 300 x 90 I can't say that I have realy noticed much lag from going bigger. I can't say I really saw any real gains from it either, but I did it for looks. I would go with what VB said, get the one that fits the easiest.
Blowing a pipe of is not really a problem because your car will run rich if you do, which means your not going to damage anything. Save your money it's probably not going to be a problem anyway.
can i just ask how big is the stock piping 2 1/2"???
I have an ARC M073 twin inlet. Used it with 2560R-5's. Upgraded from trust and the differance was staggering.
Have tested ARC/HKS/Trust/Apexi. (flow,cooling and pressure drop)
-ARC were the best hands down in every possible way, even give more flow to the radiator.
-Trust were good in the 150mm wide version (no pressue drop, reasonable cooling)
-Apexi Cool well due to having a longer 710mm core, but had some pressure drop(3psi)
-and HKS recorded pressure drop and suffered from heat soak after a few runs.
Still all better than chinese bar and plate.
For the power you are after I would use the ARC. Which supports up to 400rwkw and will give more throttle response/midrange improvement over the trust.
For over 400rwkw....up to 500rwkw the ARC M105+M109
Over 500rwkw
Trust 150mm single or twin inlet
The bell mouthed inlet on the ARC cores make prettty much all other coolers redundant
ARC technology explained
Goto products, Commentary ◎ cooler interface | 1 2 3 4 5 6 7. and flick through the 7 pages
Edited by BoostdR
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
