Sorry to anyone I havn't gotten back to need to pull things off and organise pics etc.
Wrecking as the car was needs an inspection etc and I can't justify putting a new motor in and trying to sell the car complete with the market for used cars as it is right now.
  • Replies 44
Like I said before I'll take the front & rear Kansai strut braces if they fit over my high mounts, and I'm in Adelaide.
If you'd prefer to deal locally rather than post, please PM me your contact details.
I might be interested in the Getrag too. Anyway, shoot me your contact details and I'll come around for a yarn.
Nismo arm set consists of Rear camber arms, rear lower control arms, rear traction arms, front upper camber arms. $220 per pair or $800 for the set of 8 pieces.
Interested in varoius parts and I'm in Adelaide please contact Mark : 0429 606 894 because you have not repied to the Pm I sent.
Cheers
Wrecking an R32 GTR, motor has done a bottom end so will be selling all parts seperately.
6 speed manual R34 GTR Getrag ?
HKS 4" High power exhaust pipe $500
TRUST front pipe $200
Greddy GTR aluminium radiator $650
Aragosta Coilovers $1000
NISMO arm set
ATS LSD $800
AW Work mister S2R 9J-17 $1500
TRUST front bumper
Carbon bonnet $750
N1 light and HID 6000 Kelvin $700
R34 GTR Vpec Turbos ?
Exedy triple clutch $1000
R34GT-R aluminium pedal $150
Kansai Front and rear tower bar $300
Shell will also be for sale last of all. All other parts available can send interstate.
Mate
Intereseted in the getrag.
What condition is it?
does it have transfer?
what sort of price are u asking?
thanks
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
