well I can help you out for a start, I have to complete hub assemblies from an R33 that you can have for 250 for the pair (want to sell them together), i'm sure a few others will have some spare parts in there shed that they don;t want and you'll be on the road for under $1000 because once you have all the parts the rest is just bolts.
ok, but u did say control arms, hence why it was all over the place, especially considering S13's dont have upper control arms at the front, only at the rear.
and remember, S13's and R33's both have completely different front suspension.
Yeah that's fair enough, wasn't meaning to be rude!
But yeah R33's & S13's are completely different.
control arm most likely... mine is bent too from previous accident, wore out the tie rod end as if wasnt fixed in ages. im looking at fixing it atm, the wheel is a couple cm off and you can clearly see underneath the car if its much bent compared to the other side.
Seems like a simple enough job to replace, could probably do it at home, not in this weather tho... been putting the car off for a week now :S
That looks very similar to mine Bezender. The wheel is pushed back but not as close to the gaurd as yours. Well i'm taking my car into a place monday morning to get a second opinion so i got my fingers crossed. Wasn't expecting so many replies to this haha. This weather is f**ked im prob gonna just pay up if this quote is cheaper than the last, i need my car back so bad to get to work next week.
hmm nisskid if its the lower control arm its like 250 for a second hand one good luck getting out of it that cheap.
dunno who ur buying from but if ur paying anywhere near $250 ur getting ripped off big time.
saying that, i just remembered it is a R33 not a R32, and the R33 LCA's are in a bit more demand and cost a bit more, so might be a bit more but still no where near $250.
i still marvel at how people on SAU seem to get ripped off so much :P
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
