Hey guys and girls, i'm having a bit of a problem with my 32 GTR. For the past few months whenever i drive the car with more than say, 50% throttle, the gauge shows power going to the front wheels, i've
had new tires put on (bridgestone adrenalines)...
nearly 12 months ago had a set of 17x9in driftek rims put on...
taken it to a mechanic who changed all the sensors and ran a diagnostic, no fault codes...
but...
when he put on a set or R34 rims the problem stopped...
i've re-checked the drifteks, they are all the right sizes, i just can't seem to get my head around the problem...
Have i missed anything???
Any help is greatly appreciated...
Cheers
Amph
https://www.sau.com.au/forums/topic/254654-r32-gtr-4wd-constant/
the drifteks were all the same size? tyres were all the same brand model and size?
why I ask is that I have 17x8.5's all round, with 235/45/17's all round. With different brands front compared to rear the 4wd was trying to engage just cruising, felt like a pulsing at 100kph and could see a blip each time on the gauge. swapped front to rear and it is gone. Takes bugger all to make a difference.
james
james
Yup they are all the same size, had that re-checked today, tires are brand new and were bought all together...
there is no pulsing at any speed, just the more speed you build and the further you put your foot down the more torque it sends...
If you are accelerating, then ATTESSA will get a signal from the longitudinal G-sensor (and maybe the TPS) and apply torque to the fronts. If you are simply cruising at >50% throttle, then you have a problem if you are getting front torque (sorry, don't know how to solve it if that's the case).
Today i put the original 16in tires on, it made it a little better, but it's still showing front torque at high speed and say 50% throttle...
ITS GIVING ME THE S**TS!!!!
but thanks for the feed-back, anybody else have similar problem???
that sounds to me like attessa doing what it normally does.
It will bring torque onto the fronts under mid - heavy acceleration. Basically anything sufficent to generate more then a few pound of boost. This is normal, my car does it and the half-dozen or so other GTR's I have driven also do this. Its to stop you from loosing traction under heavy acceleration. If you wanted a RWD car, you should of bought a GTST.
How wide were the R34 rims?? Maybe you need some wider & heavier rims, sounds like the system is thinking it is losing traction early. Could be that the rims are narrower & lighter confusing it maybe....
Even on light throttle applications??? 3rd or 4th gear less than 3000rpm...
what about on the freeway, say 110km/h, drop it to 4th and it starts to send power to the front...
and the faster you go the more power is being transfered.
it wasn't like this when i first bought it, in the beginning it would come in when you put your foot down, but when you were moving at a fast pace (say 80km/h +) and back off, the re-apply the throttle there would be no more front drive...
i've had it up to 180km/h (on a track of course) and there is still power being sent to the front wheels...
that just doesn't seem right....
Yeah that does sound like something has changed. Maybe take it to your local tuning shop, get them to have a look & ask them. Maybe also, a japanese wrecker on the odd chance that they have heard of this problem before. Where abouts are you located??
Sound normal to me too IF you're accelerating. If your cruising then i would expect torque to be 0.
That sounds strange. As elk says, if the g sensors are registering then some torque should go to the front. Unless of course you're cornering as well, where the system puts less drive to the fronts to prevent understeer. The other thing that will push torque to front is wheels slipping (or wheels that appear to be slipping to the system, ie when the circumference of the wheels is different front to back, or if your diffs have different ratios....)
can the tyre shop compare the rolling diamaters of each tyre? I had a similar problem, 4wd engaged on half throttle, was due to the rolling diameter being 8mm smaller on the rears, attessa thought the rear wheels were losing traction.
Yeah all the tires were put on at the same time, the rims are all exactly the same size and shape (no buckled rims)
it just seems odd that whe i put the original tires and rims back on it still had the problem (not as obvious as with the drifteks)
I've only noticed this problem in the past 2 months, since then i've also changed to tein super-street coilovers and DBA slotted rotors at the front, in regards to the suspension i was told about getting the car weighed so they can adjust the coilovers to evenly distribute the weight...
could that have an effect on the atessa???
thanks for all the help so far guys, appreciate it...
cheers
Amph
What about the tyres? Same manufacture? Same design? Same width? Same profile?
Tried swapping wheels F->R?
Try what he is suggesting. The attesa system also uses the abs senses on each wheel to sense the wheel speed. As suggested earlier, it may be thinking that the rear wheels are slipping as they are spinning slightly faster than the fronts. Are the new tyres all from the same batch? Check the rolling circumference of each tyre. You can do this youself, by putting a mark on the sidewall, roll the tyre one full circumference and measure.
Then I restate that it appears to be working exactly as designed. I have no idea why it didn't (appear to) work before. As for your new suspension, if anything it would cause an error in ATTESSA.
If the AWD light comes on, then you have an error, and you will not get torque to the fronts, no matter how hard you try.
does the 4wd light ever come on?
No never, the hicas light use to come on every now and then, but that stopped when i topped up the fluid resivour in the back...
The last place i took it to said that there was a difference of less than 4mm over the rolling diameter of all the wheels, i dont think the atessa can be that sensitive.. otherwise you'd have to change the tires front and back every few weeks...
and it's still doing it with 2 sets of wheels and tires...
the original 16's (which never had a problem when i bought the car with them on) and now the 17's
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
