running 235/45
possibly i would like to keep the guards factory..
haven't fit the front on as itll definitely scrapes my inner guard.
the rear ones are hitting inner guards
how you mean damaged rims?
Edited by Excess
I ran.. I can't remember if it was 225 or 215. Pretty sure it was 215 all around, slammed to the floor on standard front guards and it was fine
The rears had heaps of clearance but I had the inner lip on the rear guards rolled prior to R33 GTR wheels going on
How different is the offset? I'm running 17x7.5 +40 with 235/45 tyres and no rubbing on the back, 225/45 on the front no rubbing either.
I have been contemplating getting some 33gtr rims but if I can't run at least 235 tyres then I won't bother..
Edited by bubba
its +30 , you cant run 235 on the front im pretty sure unless you do guards work (which i didnt wanted to at this moment) ..
im gonna run 235 on the rear at least but my guards will be rolled..
any particular reason why you wont bother running anything lower than 235?
Obviously he doesnt like stretching tyres if he is running a 235 on a 7.5inch wide wheel. I have 225 on 8inch and they arent strected at all.
Thats it im rolling the rear guards , as my suspension being bit soft.. so if i roll the rear guards will it guarantee that with 235/45 will not scrape/hit?
i cant guarentee shit, every car is different, but chances are it will.
running 235/45
Car was damaged prior to me purchasing it, lots of damage above and below the waterline. Chassis damage, wheel lips buckled and chaffed, wiring by monkeys with brain removed, rust, graffiti.. you name it, shouldn't have bought it.. Priced up replacements considering they are sold here in aus, not jap rims, $2400 for the set. Might look into getting them repaired.
they will probably scrap eventually, just depends whether ur suspension will compress enough.
just roll ur guard and be done with it, dont know why people even bother with standard gaurds any more.
are you referring to both front and rear? or just rear ?
Edited by Excess
what rims are we talking here? 32 stockies?
both, i found my 17x9 +30 with 235's just scraped at the rear, never at the front, although i think thats to do with suspension as my 17x9 +16's with 235's never scraped either and they were mexican up front.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
