Hi everyone,
Following the success of our Skidpan Training Day on the 21-09-2003 I proposed either the Saturday 15th November or Sunday 16th November 2003 as a comeback.
Cost: $120pp, $50 deposit due as soon as we get 12 people.
Time: 1pm to 5pm (If group consist 7 people, it's 12pm to 5pm)
At this stage there we have 12 people, which I have listed below... Those who are interested please pm me or reply here:
1. rs73 (myself) - Saturday
2. king_kw13 (Kevin) - Sunday
3. R32_Skyline (Cam) - Sunday
4. Gareth (180SX+RB25DET - Cam's friend) - Sunday
5. Dragon18 (Nick) - Sunday
6. Ni (inark) :) - Saturday
7. Al - Saturday
8. RUS (Wayne) - Saturday
9. ant95GTR (Anthony) - Saturday
10. sKyLyN (Kris) - Saturday
11. Greg - Sunday
12. Meggala - Sunday
13. Jason - Sunday
The link to our previous skidpan day is here:
http://www.skylinesaustralia.com/forums/sh...&threadid=24289
As it looks like we have huge responses, I will organise two groups, one going on Saturday, one on Sunday! Please indicate preference below:
Saturday Group:
1. Inark (deposit received, thank you)
2. Al (deposit received, thank you)
3. Anthony (deposit received, thank you)
4. Kris (deposit received, thank you)
5. Wayne (deposit received, thank you)
6. Rianto (myself)
Sunday Group:
1. Nick
2. Meggala
3. Cam (deposit received, thank you)
4. Gareth
5. Kevin (deposit received, thank you)
6. Greg (deposit received, thank you)
7. Jason (deposit received, thank you)
Cheers,
Rianto
  • Replies 81
took the liberty of adding myself to the list.... saves ya time :)
btw are we alowed to bring ppl 1 spectator with us? i need a camera girl :)
oooo and i have a mate with a camera stand for the inside of the car... it firmly mounts to the headrest and doesnt budge can i have that in the car with a video camera mounted on it??
will have to see if i can borow it :)
btw are we alowed to bring ppl 1 spectator with us? i need a camera girl :D
will have to see if i can borow it :D
i dont have the headrest mount yet nark, hopefully it will arrive soon. the guy said he was expecting them weeks ago, but has sent the rest of my order of external mounting points ( suction cup thingo and security strap) i have 2 of them i can lend, wouldnt mind coming myself and doing some filming anyway. but ill see if the headrest mount comes
hi Nick,
I can pop in any day Saturday or Sunday. Need 2 more people...
inark, that suction cup looks interesting... but have you ever thought that you'll need a waterproof camera ?
All that grease and water on the skidpan not gonna be good on your camera!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
