Hi everyone,
Following the success of our Skidpan Training Day on the 21-09-2003 I proposed either the Saturday 15th November or Sunday 16th November 2003 as a comeback.
Cost: $120pp, $50 deposit due as soon as we get 12 people.
Time: 1pm to 5pm (If group consist 7 people, it's 12pm to 5pm)
At this stage there we have 12 people, which I have listed below... Those who are interested please pm me or reply here:
1. rs73 (myself) - Saturday
2. king_kw13 (Kevin) - Sunday
3. R32_Skyline (Cam) - Sunday
4. Gareth (180SX+RB25DET - Cam's friend) - Sunday
5. Dragon18 (Nick) - Sunday
6. Ni (inark) :) - Saturday
7. Al - Saturday
8. RUS (Wayne) - Saturday
9. ant95GTR (Anthony) - Saturday
10. sKyLyN (Kris) - Saturday
11. Greg - Sunday
12. Meggala - Sunday
13. Jason - Sunday
The link to our previous skidpan day is here:
http://www.skylinesaustralia.com/forums/sh...&threadid=24289
As it looks like we have huge responses, I will organise two groups, one going on Saturday, one on Sunday! Please indicate preference below:
Saturday Group:
1. Inark (deposit received, thank you)
2. Al (deposit received, thank you)
3. Anthony (deposit received, thank you)
4. Kris (deposit received, thank you)
5. Wayne (deposit received, thank you)
6. Rianto (myself)
Sunday Group:
1. Nick
2. Meggala
3. Cam (deposit received, thank you)
4. Gareth
5. Kevin (deposit received, thank you)
6. Greg (deposit received, thank you)
7. Jason (deposit received, thank you)
Cheers,
Rianto
  • Replies 81
took the liberty of adding myself to the list.... saves ya time :)
btw are we alowed to bring ppl 1 spectator with us? i need a camera girl :)
oooo and i have a mate with a camera stand for the inside of the car... it firmly mounts to the headrest and doesnt budge can i have that in the car with a video camera mounted on it??
will have to see if i can borow it :)
btw are we alowed to bring ppl 1 spectator with us? i need a camera girl :D
will have to see if i can borow it :D
i dont have the headrest mount yet nark, hopefully it will arrive soon. the guy said he was expecting them weeks ago, but has sent the rest of my order of external mounting points ( suction cup thingo and security strap) i have 2 of them i can lend, wouldnt mind coming myself and doing some filming anyway. but ill see if the headrest mount comes
hi Nick,
I can pop in any day Saturday or Sunday. Need 2 more people...
inark, that suction cup looks interesting... but have you ever thought that you'll need a waterproof camera ?
All that grease and water on the skidpan not gonna be good on your camera!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
