Need i say more, bloody commo drivers.
Last night driving home, out of nowhere this commo comes from the right lane and cut me off, i was in the left lane on main north road and he decided he wants to turn left down John rice ave.
Smashed up the front, not sure if right off yet, have to wait assers decision.
May be wrecking with heaps of parts available.
Will post up when i hear verdict.
Cheers to Ben for hanging around when the crash happend, Sorry i can't remember your misses name, but also thanks.
https://www.sau.com.au/forums/topic/255050-commo-losers/
  • Replies 41
Posted Images
Bad news - hope you are okay. As the airbags have deployed it will almost certainly be a write off although if your chassis is not bent the front looks repairable - buy the wreck and get an R34 front!
[nb Stageas had a 5 star crash rating and having written mine off after leaving the highway and hitting a culvert I can say it is well deserved - I walked away with a few cuts and bruises and a headache].
https://www.sau.com.au/forums/topic/255050-commo-losers/#findComment-4400649
Me and the misses walked away ok, just shocked the hell outta me.
Yeah i didn't even consider the airbags.
I always said if the front got damaged i'd do the 34 front, but i think the damage is a bit too extensive.
https://www.sau.com.au/forums/topic/255050-commo-losers/#findComment-4400660
bloody holden drivers. saw a heap of fools last night in holdens.
some dick in a vs calais on princess hwy, does a huge stand still smokes up the whole intersection then flies.
another fool comes up next to me... then boots it, hit 120 plus easy. never any cops around when you need one...oh yeah both P platers
https://www.sau.com.au/forums/topic/255050-commo-losers/#findComment-4400718
f**k man! thats no good at all! i remember my crashes (not in the stag) and its the most annoying thing ever! was 1 of the sickest s1s around adelaide! if you need help stuff im more than kool to help out... also ive gota crash reparer that i highly highly reccomend, just cars wrote my car b4 the stag off and he gave them quotes and spoke to em and they repared it!! being a stag tho may be hard to get shit for it! Norwood panel works is the place. pm me for details if your keen man
https://www.sau.com.au/forums/topic/255050-commo-losers/#findComment-4400719
shit man sorry to hear about this, i know i would absolutely devastated if my stag got written off, even tho it would be cool going on the search for a new one, and a nother big road trip back to cairns haha
hope all works out for you mate
https://www.sau.com.au/forums/topic/255050-commo-losers/#findComment-4400778
Ouchy...
Thankfully (for you) the impact doesn't look like it was too great.
If there's one driving trait that I'm starting to notice more around here, it's blind lane changing. Usually by people who get upset at you for being in their way!
https://www.sau.com.au/forums/topic/255050-commo-losers/#findComment-4401008
Hope you are alright...those F%&**)(G commohoons are all over the place...I live near Fountain Gate SC and friday and sat nights are meet and burn area...plus every time they stop close to you they look at your car and want to race you...
Again happy that nothing happened to you and very sorry for your ride...
https://www.sau.com.au/forums/topic/255050-commo-losers/#findComment-4401399
Getting the car towed back to my house today so i can asses the damage a bit better.
Has anyone had to replace airbags?
The steering wheel will be no problem but i'm just thinking about the passenger side whether it will just require the airbag and the cover rather than having to replace the whole dash.
Also do series 1 have seat belt pretensioners? if so will they need replacing?
All help appreciated.
https://www.sau.com.au/forums/topic/255050-commo-losers/#findComment-4402077
bonnet has gone back into windscreen.
strut brace bent, hopefully it hasn't pushed out the LH side.
gaurds been pushed back up the A pillars.
Battery been pushed back into fuse and relay box
Heaps of other stuff, haven't put on hoist yet to check underneath.
Alot of panel damage, can't dismantle yet as i gotta wait for insurance bullsht.
Too bloody hot outside and i hate looking at it. :P
https://www.sau.com.au/forums/topic/255050-commo-losers/#findComment-4402761
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
